March 24, 2026, 03:27:23 AM *
Author Topic: Baker vs radiator pod  (Read 1109 times)
designer
Columbus, Ohio
« on: June 02, 2011, 07:40:47 PM »
Anyone that has used both of these what was your opinion? Air deflection? Turbulance? Additional deflectors needed for the pods or baker wing? Thx
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
« Reply #1 on: June 02, 2011, 08:00:01 PM »
Pods are mostly for looks.  They're highly ineffective at moving air.
Lose the screen and you'll stop worrying about air flow.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #2 on: June 02, 2011, 08:26:35 PM »
You need to be more specific.  Do you have an I/S and need to know about Pod deflectors vs. Baker Airwings?  Or do you have a Std or Tourer and wondering about adding pods or Bakers?  What is it?
On my I/S I have Bakers and Hondaline Pod Deflectors and Hondaline Fork Deflectors.  Perfect combination and I wouldn't be without either.  I added fully functional I/S Pods to my Std along with the pod deflectors.  Couldn't put Bakers on that set up because of the fairing I put on.  Also fork deflectors on the Std.  Again, Big improvement.  Highly effective at air management, either cold weather or hot.  Oh, and no turbulence.
In this picture, I hadn't installed the pod deflectors yet.
Should be able to see the both sets of air deflectors.
States I Have Ridden In
x
0
« Reply #3 on: June 02, 2011, 08:33:28 PM »
I had Bakers on both my Tourer and I/S.  Much more effective than the pods.  The two part set up on the Tourer Bakers also allows for rain deflection off the legs, and when set to open, does a good job of reducing head buffeting by pushing up more air in behind the W/S.
Jess Tolbirt
White Bluff, Tn.
« Reply #4 on: June 02, 2011, 09:29:36 PM »
the pods are there to take the radiator heat and throw it out the side,,,,and man does it work!!!!!! i can now ride my bike in 100 degree heat where as before the pods when that fan kicked on it would roast my er uh little thingys,,,
Valkyrie member # 23084
designer
Columbus, Ohio
« Reply #5 on: June 03, 2011, 04:58:00 AM »
I have a standard and like the looks of the pods and the ideal of having additional lights in the pods. But I don't want to lose the air flow metering/control. With a windshield it's nice to direct air up behind it to help with helmet cooling/body cooling.
2002 Valkyrie Std
