February 02, 2026, 07:49:43 PM *
Author Topic: Will driveshaft pinch/bind with swingarm dangling  (Read 1524 times)
CASABROKER
« on: July 03, 2011, 11:18:23 PM »
Shocks off changing tire swingarm dangling any danger to drivehaft?
ValkFlyer
Antioch, CA
« Reply #1 on: July 04, 2011, 02:07:55 AM »
Yes, if you're allowing the swing arm to hang with the tire on it you risk damaging the yoke.  Support the arm or you may damage the bearings in the U-joint.
« Last Edit: July 04, 2011, 02:10:13 AM by ValkFlyer » Logged
« Reply #2 on: July 04, 2011, 05:39:00 AM »
Just a suggestion but why don't you pull the final drive and shaft and service it while you are doing the tires . Clean splines , pinion cup, driveshaft and replace fluid in stump , check o-rings , check dampers etc. I've got one of my Valkyries in the air on the lift right now doing new tires , brake pads and service to final drive.
« Last Edit: July 04, 2011, 05:41:37 AM by Smokinjoe-VRCCDS#0005 » Logged
