February 02, 2026, 07:48:32 PM *
Author Topic: 1:1 vs 3:2...Coolant ratio question  (Read 1492 times)
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« on: July 05, 2011, 03:23:59 AM »
I need to change the coolant in the Valk.....I bought a gal. of the Prestone 5/150 world silcate-free and as I was getting ready to do the job, I thought I would double check the capacities and it actually calls for. The gallon is 1:1 and if I add a quart of distilled water that 1:1 is now 3:2 water to antfreeze........is that important enough to worry about........
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: July 05, 2011, 04:24:38 AM »
Mornin Rdkll, I'm guessing you brought the premix.  Just drain and replace.
Marty
Bobbo
Saint Charles, MO
« Reply #2 on: July 05, 2011, 09:24:16 AM »
A 3:2 mix will raise the freezing point and lower the boiling point of the coolant.  That mixture would be a 40% solution which has a freezing point of -10 F and a boiling point of 220 F.  A 50% mix has -30 F and 225 F respectively.  Since the freezing point is affected most, you will be fine as long as it doesn't sit outside during a cold PA winter!
