February 03, 2026, 05:49:21 AM *
Author Topic: Peg Relocation  (Read 2645 times)
Gideon
Indianapolis, IN.
« on: July 25, 2011, 07:55:05 PM »
Since Chet /Rattlebars has retired and no longer makes a Peg Relocation kit, I made a knockoff from ¼ x2” 4140 bar stock. It drops the pegs an 1 1/4”. However, can anyone give me a photo or directions that show me how I need to move the shifter?  Smiley
designer
Columbus, Ohio
« Reply #1 on: July 26, 2011, 06:25:42 AM »
are you trying to move the shifter... where.  you can only pivot it around the  shaft, you can't really make it longer or shorter without finding a longer or shorter shifter.  The peg relocation moves the peg down and can move it forward varying amounts.  Give you more toe room under the shifter.
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
Gideon
Indianapolis, IN.
« Reply #2 on: July 26, 2011, 10:06:31 AM »
Thank you for your reply. I understand about rotating the shifter.  That was actually my question.  I thought there were some instructions about rotating the shifter in relationship to the punch mark on the shaft.  If I recall correctly, Chet had a photo that showed the slot in relationship to the punch mark. I am just looking for a starting point for moving rather than a move it, use it, move it set- up. (Trial and error) Smiley
Gideon
Indianapolis, IN.
« Reply #3 on: July 28, 2011, 01:36:31 PM »
Just an update. I rotated the shifter to the right, 2 notches. took a 164 mile ride. With the peg being an 1 1/4" lower, 1 1/4" forward and me having a size 12 Boot, the ride was very comfortable.
Thanks again.
God bless,
Bob Dillon Smiley
doubleminded
denton texas
« Reply #4 on: September 01, 2011, 02:25:30 AM »
I SURE WOULD LIKE TO SEE OR KNOW HOW YOU DID THIS SO I COULD DO IT.
Jesus likes vakyries.
Gideon
Indianapolis, IN.
« Reply #5 on: September 01, 2011, 01:51:43 PM »
If you look at the gearshift arm, you will notice a split at the top. It lines up with a punch mark on the spindle. I removed the bolt that holds the gearshift arm onto the spindle and slid the gearshift arm off the spindle. I then slid it back on to the spindle aligning the split two notches to the right of the punch mark, installed the bolt and tightened to secure the gearshift arm to the spindle. This lowered the gearshift arm and peg enough to make it comfortable for me. If you send me an email, I would be glad to reply with a photo as I do not know how to post pictures on this site. I tried, it just didn't work.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #6 on: September 01, 2011, 07:41:14 PM »
There is 2...Two places to adjust the shift lever to get it where you need it.  coolsmiley
States I Have Ridden In
Big Mike
I can not remember my last bad day
Taylor MI
« Reply #7 on: September 02, 2011, 08:36:34 AM »
I have 6 sets that are ready to go, with more on the way. These initial 6 will be $99 delivered with conditions. If you are interested send me an email with your number and we can discuss it. You may also call
Big Mike
VRCC 23871
VRCCDS 0200
With GOD and a good attitude, there is no circumstance that I can not overcome.
Trynt
So. Cen. Minnesota
« Reply #8 on: September 02, 2011, 01:07:15 PM »
My solution. Shifter arm is threaded.
doubleminded
denton texas
« Reply #9 on: September 04, 2011, 04:34:22 AM »
my email is ronbayless57@gmail.com
Gideon
Indianapolis, IN.
« Reply #10 on: September 04, 2011, 06:55:01 PM »
email sent
Trynt,
Would you please send me an email so that I could possibly in the future post a photo if needed.
I am happy to see that someone is going to start making the peg relocation kit.  It works and improves the ride.
God bless,
Bob
