February 03, 2026, 05:49:15 AM *
Author Topic: Kury grip problem  (Read 2166 times)
Stitch_in_La
Bentley Louisiana
« on: September 02, 2011, 08:32:07 AM »
Got a set of Kury Iso-vibe grips the little black rubber things are making everything that touches them black.  Is there a way to remove the excess blackness that is leaking out.  Or just change the grips?  Also if change grips good way to get them off??
Thanks in advance
Stitch
The Anvil
Derry, NH
« Reply #1 on: September 02, 2011, 08:39:01 AM »
I'm thinking that whatever you used for grip glue might have reacted badly with the rubber.
greggh
OMAHA NE
« Reply #2 on: September 02, 2011, 10:38:06 AM »
Not true regarding the Glue.
I have the very same problem, the palm of my hads get dirty fromo the grips after a day or 2 of  not washing the bike.
After washing the bike all is well.  My thought is that the detergent used to was might be aiding in creating the grips to be a bit more tacky.  With the wind blowing the dust then clings to the grips and eventually ends up getting the grips dirty.
A pair of fingerless glives resolves this problem or I some times washt the grips with just wetting a towel.
I give it a PITA factor of about 7.
Just my opionion.
Gregg
The Anvil
Derry, NH
« Reply #3 on: September 02, 2011, 10:49:54 AM »
Just my opionion.
Gregg
But dirty or rubber black?
I mean I have no idea. Could be the type of rubber they use reacting with acid in sweat or something else, I just suggested the glue because it's another chemical that comes into contact with the rubber.
six2go #152
Ft. Wayne, IN
« Reply #4 on: September 02, 2011, 11:04:55 AM »
GLOVES!
Fritz The Cat
« Reply #5 on: September 02, 2011, 11:46:07 AM »
I had a set for over a year and they never stopped doing this. When the chrome started peeling, that was the last straw. I got rid of them and will never buy a Kury product again.
« Reply #6 on: September 02, 2011, 03:21:54 PM »
Try giving them a good scrubbing with Armor-all.
X Ring
VRCC #27389, VRCCDS #204
« Reply #7 on: September 02, 2011, 03:24:36 PM »
I had a set that did that and the only solution was to replace them.  Something is causing the rubber inserts to oxidize.
Marty
Dougger
Titusville, Fl
« Reply #8 on: September 02, 2011, 04:51:32 PM »
I have had Iso grips on two bike and I am planning on putting on the 3rd bile. Never habe had a problem, but I wear gloves
« Reply #9 on: September 02, 2011, 05:49:19 PM »
Ive had Kury flame gripes for two yers now.....never a mark from the grips on my hands.
Heres a thought....if you use moly grease on the pivots for the handles, it will oooz out to your hands and turn them black...........
sidecarrick
VRCC 13089
windsor,ontario,canada
« Reply #10 on: September 02, 2011, 06:59:11 PM »
+1- really works!!
Red Diamond
Beaumont, Texas
« Reply #11 on: September 02, 2011, 09:12:42 PM »
Chris, I have the same grips you have on the Tourer, my gloves turned black the first time I rode with them. After a year they are better now.
fudgie, I don't know about that Armor-all, it's kind of slippery.
FloridaValkRyder
Apopka, Florida
« Reply #12 on: September 03, 2011, 04:09:10 AM »
Same here, I love the grips but I never ride without gloves. I just went out and rubbed my hands on my grips..no black, yet.
I still miss her.
MacDragon
My first Valk VRCC# 32095
Middleton, Mass.
« Reply #13 on: September 03, 2011, 04:43:07 AM »
That is kinda weird... I've had ISOs on all my bikes with no transfer of black ever... Bad batch of rubber from Kuryakyn maybe???
Patriot Guard Riders
« Reply #14 on: September 03, 2011, 04:43:56 AM »
Yes but wears off fast. Just need enough to get the black off. Wont cause you not to loose grip since your not 'hanging on'.
Stitch_in_La
Bentley Louisiana
« Reply #15 on: September 03, 2011, 06:29:45 PM »
Definatly a rubber not dirt problem.  Have two other bikes with the Iso grips no problems from them.  Will give the armoe all a shot.  How about removal tips, will be a new experience if ti comes to that?
Stitch
