February 03, 2026, 12:05:06 PM *
Author Topic: first oil change  (Read 2229 times)
fubar606
eastern washington
« on: October 15, 2011, 12:18:06 PM »
is there only one drain plug on my 2000 interstate or 2 like my vtx
life is sexually transmitted and always fatal
YoungPUP
Valparaiso, In
« Reply #1 on: October 15, 2011, 12:20:59 PM »
1 on the right side. Look in shop talk under Sgtt. Joe's oil change instructions.  Kinda odd but simple instructions.
99 STD (Under construction)
Farther
Quimper Peninsula, WA
« Reply #2 on: October 15, 2011, 12:29:47 PM »
Whoa, you must have a lot of miles on the first oil change. Roll Eyes
This link may help if it works: https://www.ahm-ownerlink.com/Maintenance/maint_procedures_popup.asp?con=/Assets/OWNERLINK/Maintenance/Procedures/GL1500_03_CHOIL.XML
« Last Edit: October 15, 2011, 12:32:42 PM by Farther » Logged
~Farther
fubar606
eastern washington
« Reply #3 on: October 15, 2011, 12:53:24 PM »
its new to me just pick it up 3 days ago so i am going through it making sure everything is what it should be. I'm out to the shop to make a jack adapter so i can do the back end next.
 its a 2000 interstate about 60,000 on her seems to be pretty good shape sofar Cool
YoungPUP
Valparaiso, In
« Reply #4 on: October 15, 2011, 06:09:36 PM »
Great Plan going through it as a precaution. Welcome to the Insanity!
highcountry
Parker, CO
« Reply #5 on: October 15, 2011, 07:33:37 PM »
Do the coolant while you are at it.  The Valk is one of the easiest bikes to service that I have owned.
9Ball
« Reply #6 on: October 16, 2011, 02:49:26 AM »
don't forget fresh clutch and brake fluid too....makes a world of difference and definitely a safety issue.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Chiefy
Sarasota, Florida
« Reply #7 on: October 16, 2011, 09:07:26 AM »
Congrats and welcome aboard.
Chiefy
Sarasota, Florida
« Reply #8 on: October 16, 2011, 09:14:00 AM »
BF posted these links for me when I first got mine:
Here's a few links with some info you might find useful......
http://www.valkyrieriders.com/shoptalk/
http://www.timskelton.com/valkyrie/tech/index.htm
http://lifeisaroad.com/stories/2004/10/26/techTips.html
http://www.valkyrieguy.com/
http://hammer.prohosting.com/~schutzrs/tech.htm
http://www.timskelton.com/valkyrie/index.htm
http://www.visi.com/~spookshow/valkyrie.html
http://www.virtualbiker.com/valkyrie/
http://www.rattlebars.com/mtz/valkyrie.html
http://www.rattlebars.com/valkfaq/circuits.html
http://www.rattlebars.com/mtz/starter.html
http://www.hdlparts.com/fiche_select2.asp?category=Motorcycles&make=Honda&year=1997&fveh=3465
http://www.directlineparts.com/
http://www.bigbf.com/
Service manuals:
http://www.valkyrienorway.com/index.html
fubar606
eastern washington
« Reply #9 on: October 19, 2011, 03:18:44 PM »
All good info for a new guy.
             from what i have poked around with my fat girl the swing arm back isn't
             much different than dealing with my "X". why so much caution with loosening the final drive (4) bolts to line the splines.  its it different than taking the final drive out of the "X"thats
    pretty straight forward
  guess what i am asking if i don't have any trouble with the "X" final drive i shouldn't have any with the valk right ?
« Last Edit: October 19, 2011, 03:20:50 PM by fubar606 » Logged
« Reply #10 on: October 19, 2011, 04:10:12 PM »
The Valkyrie final is different from the VTX,  alignment is more sensitive because the flange kinda floats it has no bearing in it like the "X" did.  This subject (the four bolts) has been covered many times in here, I agree with your hypothises that in theory you shouldnt have to mess with the four bolts unless you are removing the final drive.  However, those of us that have been around these things long enough have either learned the hard way or know someone that has.  Loosen the bolts if you are not removing the drive.  But bigger yet, unless its a flat repair or some other reason to remove the wheel shortly after a grease job....remove the drive and inspect/grease the drive shaft and pinion cup every time the wheel comes off
« Last Edit: October 19, 2011, 07:23:18 PM by Chrisj CMA » Logged
fubar606
eastern washington
« Reply #11 on: October 20, 2011, 01:51:17 PM »
OK i have a manual coming so i know what you are talking about.
   so it is a bit more involved than an "X"  i will need to learn all is stuff . I will have lots of new guys questions.
                 got the new front tire on, and Dyan beaded up, windshield cut down, fluids checked and changed, looked for lose things,got seafoam in my first tank of gas.
          i am going to take her for a short ride tonight just to feel her run cooldude
