Fritz The Cat
« on: December 06, 2011, 04:05:46 PM » |
Been doing my homework and there's a question I can't seem to find the answer to. Well, 2 questions, actually.
1. How do you know when the Methanol has finished boiling off?
2. How can you tell when the ethanol has finished boiling off?
In regards to the Methanol, I'd really like a sure fire way of avoiding it entirely, it's some nasty stuff.
RoadKill
« Reply #1 on: December 06, 2011, 04:16:58 PM » |
What country will you be trying this in? What you are inquiring about is VERY illegal in the USA. The B.A.T.F would NOT be pleased.
RoadKill
« Reply #2 on: December 06, 2011, 04:22:33 PM » |
Those chemicals only boil with in a certain temperature range. When above or below that temp they are not vapor. You take off heads and tails because as the temp. comes up it goes throughtheir boiling ranges and as temp drops back down they will also boil again. It's in the mash and stays there when not boiling.
« Reply #3 on: December 06, 2011, 04:28:09 PM » |
Obviously, this product is for external use only. Therefore, one must assume this alcohol will be used as fuel.
VRCC# 29981 Learning the majority of life's lessons the hard way.
RoadKill
« Reply #4 on: December 06, 2011, 04:35:20 PM » |
Obviously, this product is for external use only. Therefore, one must assume this alcohol will be used as fuel.  Have to have a permit and be inspected to do that too
Fritz The Cat
« Reply #5 on: December 06, 2011, 04:37:38 PM » |
This is strictly for research purposes only.  So how do you know when the bottom ends, the middle begins and the top begins? Is it a matter of time?
Pete
« Reply #6 on: December 06, 2011, 04:38:06 PM » |
It is NOT illegal to make and consume up op 200 gallons per year for your PERSONAL use.
DO NOT sell it or even give it away, just use.
RoadKill
« Reply #7 on: December 06, 2011, 04:42:01 PM » |
That is for NON distilled beverages, wine and beer. Even a pot stil for brandy is tax evasion among other things Fermentation-Legal ... Distillation-jail and fines
« Last Edit: December 06, 2011, 04:59:55 PM by RoadKill »
« Reply #8 on: December 06, 2011, 04:49:20 PM » |
Remember that methanol consumption, even mixed with ethanol, can lead to blindness.  What does all of this discussion of moonshine have to do with Valkyries?
RoadKill
« Reply #9 on: December 06, 2011, 04:50:35 PM » |
This is strictly for research purposes only.  So how do you know when the bottom ends, the middle begins and the top begins? Is it a matter of time? A very accurate thermometer is how you know. 172.6 degerees...then dump what you have so far and dont let it drop below or get above while taking off. all good from there until temp drops. You only want the middle of the batch. put the rest back thru' in next run and take from middle again.
RoadKill
« Reply #10 on: December 06, 2011, 04:51:40 PM » |
Remember that methanol consumption, even mixed with ethanol, can lead to blindness.  What does all of this discussion of moonshine have to do with Valkyries?  Agreed !! DO NOT DRINK METHANOL!  Probably a big part of the reason it's regulated so strictly. That and the TAXES thing.
musclehead
« Reply #11 on: December 06, 2011, 05:03:58 PM » |
thats the way it used to be, I sure hope they left it alone. I'm not holding my breathe, this government loves to regulate.....
Momz
« Reply #12 on: December 07, 2011, 06:03:24 AM » |
Anyone have a good Methanphetimine recipe?
 ALWAYS QUESTION AUTHORITY! 97 Valk bobber, 98 Valk Rat Rod, 2K SuperValk, plus several other classic bikes
czuch
« Reply #13 on: December 07, 2011, 07:26:38 AM » |
^^^^^^^^^^^^^^AHAHAHAHAHAHAHAHAHAHAAAAA Weed farm?? Ride the Valk To it and stuff saddle bags. Now its sorta Valk related.
« Reply #14 on: December 07, 2011, 09:06:49 AM » |
What does all of this discussion of moonshine have to do with Valkyries?  You obviously never been to a Valk gathering!
« Reply #15 on: December 07, 2011, 09:08:06 AM » |
Anyone have a good Methanphetimine recipe?  You want a normal 'lab' or the 'one pot' method recipe?
flcjr
« Reply #16 on: December 07, 2011, 09:14:19 AM » |
its legal if the ethanol your making as is used as fuel but don't forget to pay your road taxes.
musclehead
« Reply #17 on: December 08, 2011, 02:25:19 PM » |
What does all of this discussion of moonshine have to do with Valkyries?  You obviously never been to a Valk gathering!  or my wedding, I had a couple of shots of 'dutch courage' before hand. my lovely bride got on my case for not sharing
« Reply #18 on: December 08, 2011, 05:23:04 PM » |
Bama Red
« Reply #20 on: December 08, 2011, 07:10:13 PM » |
Never corner anything meaner than yourself. VRCC Member #32561
