March 29, 2026, 12:17:43 PM
What size seat mount bolts?
Topic: What size seat mount bolts? (Read 689 times)
WDAN
Irving, TX
February 26, 2012, 08:51:38 PM »
Does anyone know what size the seat mounting bolts are on the Valk? I think 6m but length and maybe pitch.
Need to order with plastic thumb heads.
Thanks in advance
WDAN
Irving, TX
Re: What size seat mount bolts?
February 27, 2012, 06:36:02 AM »
Which bolts are you referring to, the front two that hold down the corider's seat? If so, I certainly wouldn't use anything plastic for that.
WDAN
Irving, TX
February 27, 2012, 06:56:44 AM »
I am referring to the front two and the rear also.
I want to buy a stainless bolt with a large round black plastic head on it. Just need to know specs on bolts.
WDAN
Irving, TX
February 27, 2012, 07:17:10 AM »
Hey Buckwheat, the only bolts on the front seat are the ones that hold the plastic stump that you slide into the rear fender and the loop that it locks down into. Those bolts do not need to be removed to take the seat off.
The rear seat has 2 bolts holding the rear of it down. If this is the seat you are referring to, just take 1 of the bolts out that is visible at the rear of the seat and head to ACE hardware to get the size and thread pitch, then order whatever you think you need a plastic thumb handle for it. Sounds like you want to make it a solo bike in short order. If that be the case, carry a ratchet, a short extension and a 8 or 10 socket.
Kind of think maybe ya got the wrong motorcycle you are referring to.
