February 04, 2026, 10:37:35 AM *
Author Topic: cluych fluid?  (Read 1241 times)
raker
« on: March 16, 2012, 04:29:30 AM »
when I put my 97 standard into first gear the bike it kinda learches forward. not really a learch but you can feel it go into gear hard. my mechanic says it could be from running amsoil, says its too thin. the clutch fluid has not been changed in years, do you think changing the fluid could make it go into gear smoother?
9Ball
« Reply #1 on: March 16, 2012, 04:35:29 AM »
it's a cheap and easy way to find out....and your mechanic sounds like he's on a fishing expedition.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
olddog1946
Moses Lake, Wa
« Reply #2 on: March 16, 2012, 07:48:18 AM »
Mine has done that as long as I have owned it..now have about 44000 miles on it. Actually does it less with AMSOIL in it.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
sugerbear
wentzville mo
« Reply #3 on: March 16, 2012, 08:08:25 AM »
normal
aslondon
VRCC #4321
Monticello, Fl
« Reply #4 on: March 16, 2012, 08:38:31 AM »
Every Valk I've ever owned has done that. If I remember, there was actually a thread quite a while ago consensus was it's normal.
Al
« Reply #5 on: March 16, 2012, 09:01:07 AM »
LOOK IN THE LITTLE WINDOW on the clutch master cylinder.
If it is dark, it is time to be changed.
Same goes for the front brake and rear brakes.
When I do one, I do the other 2.
GotValk
Champlin, MN
« Reply #6 on: March 16, 2012, 05:14:36 PM »
I'm in the same boat as RJ if your doing one it just as easy to do them all, About every other year for me. I don't wait until it's dark yellow.
To me fluids changes are easy prevention.  cooldude
