April 01, 2026, 01:08:34 PM *
Author Topic: valkyrie handlebars  (Read 10066 times)
castilecreek
« on: June 24, 2012, 06:44:14 AM »
Greetings all, Wondering if anyone out there has any trouble with their shoulders from riding the valkyrie? I've been riding it for six months and all the sudden I'm having a considerable amount of pain in my shoulders. Also wondering if there is a fix for the problem? I'm thinking its something to do with the handlebars.
Alien
Ride Safe, Be Kind
Earth
« Reply #1 on: June 24, 2012, 06:50:43 AM »
Yep.  Same problem.  I put these riser extensions on and no more pain.
http://www.ebay.com/itm/Honda-Valkyrie-GL1500-Gl-1500-Handlebar-Risers-/190687430834?hash=item2c65db48b2&item=190687430834&pt=Motorcycles_Parts_Accessories&vxp=mtr
(I'm not the seller or affilliated with the seller but in dealing with him I found his workmanship and customer service to be top notch.)
Jess Tolbirt
White Bluff, Tn.
« Reply #2 on: June 24, 2012, 07:06:13 AM »
lower your handle bars one inch and give it a try,,,that was an instant fix for me...
Valkyrie member # 23084
Tropic traveler
Silver Springs, Florida
« Reply #3 on: June 24, 2012, 11:25:02 AM »
Rarely does a bike fit the rider as is. Seat, bars & pegs can all be tweaked to fit your induvidual needs.  cooldude
'13 F6B red for Kim
Master Blaster
Deridder, Louisiana
« Reply #4 on: June 24, 2012, 11:49:19 AM »
Try a set of Deuce risers, fairly cheap great looking fix that lets you adjust the angle of the bars for a custom fit.
sidecarrick
VRCC 13089
windsor,ontario,canada
« Reply #5 on: June 24, 2012, 02:19:39 PM »
Yup!  cooldude
junior
new hampshire
« Reply #6 on: June 24, 2012, 03:05:16 PM »
tourq your tripple tree bearings
Fritz The Cat
« Reply #7 on: June 24, 2012, 03:08:38 PM »
Do they even make them for the Valk? All I can find is Harely.  ???
Master Blaster
Deridder, Louisiana
« Reply #8 on: June 24, 2012, 04:43:19 PM »
The Harleys work just fine.  You have to ream the mount holes in the top triple slightly.  It isnt enough that you cant go back to stock if you desire.   Probably several hundred on this board have done this mod, and I have never heard of anyone regretting it.
castilecreek
« Reply #9 on: June 24, 2012, 04:57:30 PM »
Thanks for all help, planning a trip to the black hills next month and its certainly not the time to start having an issue like this.
X Ring
VRCC #27389, VRCCDS #204
« Reply #10 on: June 24, 2012, 06:57:21 PM »
Sand the bottom flat then drill the mounting holes to 1/2 inch.  The holes are 12mm and 1/2 inch is 12.7mm so you are barely removing any metal.
Marty
Disco
Republic of Texas
« Reply #11 on: June 25, 2012, 03:30:33 AM »
Drilling the tree may only be a removing a little metal, but there is no need to if you use these adapter bolts from Baron.
Description:
Stud kits allow most Harley-style risers with standard ½” x 13 threads to be converted to mount on Honda, Yamaha, Suzuki and Kawasaki cruisers
All studs have one end that is ½”-13 x ¾” that threads into the riser’s base
The other end of the stud and the shoulder are machined to fit the triple tree of the different manufacturers
Includes 2 studs, 2 aircraft nuts, 2 washers and 2 jam nuts
Studs thread into risers allowing mounting to metric triple trees
Installation is easy and instructions are included
Riser bolt kits have the following dimensions - check your bike for correct fitment prior to purchase:
Honda models: (12mm x 30mm stud w/10mm D x 11mm shoulder)
http://www.baroncustom.com/catalog/display/1182/index.html
22 CRF450RL, 19 BMW R1250RT
78 CB550K, 07 Helix
71 MT50 Trailhopper
Spirited-6
Nicholasville, Ky.
« Reply #12 on: June 25, 2012, 05:48:39 AM »
Jess is right on.
OR , raise a little. Worked for me on the Valk. & Spirit 1100.
Easey way first.  Wink
Spirited-6
Fritz The Cat
« Reply #13 on: June 25, 2012, 06:30:53 AM »
One more question - Why are these so mush cheaper than any others I've found?
http://www.demonscycle.com/Handlebars-and-Hand-Controls/Handlebars/Chrome-Custom-Handlebars-p9786310-2-1.html
sugerbear
wentzville mo
« Reply #14 on: June 25, 2012, 06:50:41 AM »
those are 2in setback. correct me if i'm wrong but the duece is 4 in setback.
and with something as important as steering components, i would want to be SURE they were solid and machined correctly. for $40 there has to be corners cut somewhere.
another member bought some risers that broke through the casting.
not that same type but...
just my opinion.
Six Guns
Fort Worth, Texas
« Reply #15 on: June 25, 2012, 07:16:17 AM »
You need to read this from Daniel Meyer first.
http://lifeisaroad.com/blog/2009/05/19/annnd-nobody-died/
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #16 on: June 27, 2012, 01:37:54 PM »
I've been having some right wrist/elbow/shoulder pain as well, and had remembered seeing a thread here a long time ago about it, but couldn't find it using the search feature.
I just ordered these: http://www.directlineparts.com/product.asp?pid=13483 and will let everyone know how they work out for me.  Got them from a local shop (M&M Leather in Greensburg, no affiliation etc), with the stud kit, for $76 out the door.
Fritz The Cat
« Reply #17 on: June 27, 2012, 04:19:13 PM »
Well hell, just went out and looked at mine. They're Lamonsters so I guess I'll stick with them. I thought they were stock. That'll teach me not to think next time.  crazy2
« Reply #18 on: June 27, 2012, 06:39:25 PM »
Fritz, I have the Aeromach (same as your HDL LaMonsters) risers on one bike, and the Deuce on the other.
When I put the Aeromach on, there was a huge improvement from the 3 1/8" stock risers (no more shoulder fatigue and better handling, straighter/cleaner slow riding and stops).
The Deuce came on my 2d bike, and I like them too, but at 5'9" 33" shirt sleeve, the Aeromach are better for perfect handling at all speeds, and the Deuce are better when kicked back on the HWY pegs leaning into the backrest, purely cruising (though I do the twisties with them too).  JMHO
Also the Aeromachs require nothing more than turning the wire clips on the bars 180*, the Deuce generally need rerouted throttle cables (inside the tree).
Also remember, any bars can be loosened in the risers and rotated up or down a few degrees.
