Stanley Steamer
« on: June 28, 2012, 04:02:46 PM » |
Stanley "Steamer" "Ride Hard or Stay Home"
Davemn
« Reply #1 on: June 28, 2012, 05:03:42 PM » |
Looks good. How do you shovel snow off those pavers? Oh! never mind.
« Reply #2 on: June 28, 2012, 05:07:52 PM » |
I've never seen blocks shaped on the inside like those. Any significance to the way they are moulded??
Michvalk
« Reply #3 on: June 28, 2012, 05:58:32 PM » |
That REALLY looks good, Stanley.
97ValkSteve
« Reply #4 on: June 28, 2012, 06:02:02 PM » |
Wow! Really nice job. Nice landscaping. Steve
Stanley Steamer
« Reply #5 on: June 28, 2012, 06:39:32 PM » |
First time I had seen any molded like that also.......it didn't matter so much as long as you use them in a retaining wall fashion or in an enclosed planter like this one.....darn things weighed around 80lbs each.....took almost 300....my poor back!!.....
Stanley Steamer
« Reply #6 on: June 28, 2012, 06:40:38 PM » |
Snow??......in GA??.......yeah, we sometimes get maybe 3-6" for a day or so.....ice melter usually does the trick!!......
Stanley Steamer
« Reply #7 on: June 28, 2012, 06:42:42 PM » |
Thanks guys......This is the first time I've ever built a stacked block wall.....I've done PLENTY of crosstie retaining walls, steps, planters.....so, I took my time and made sure everything was level and square and made especially sure I compacted the base....
« Reply #8 on: June 28, 2012, 07:46:21 PM » |
First time I had seen any molded like that also.......it didn't matter so much as long as you use them in a retaining wall fashion or in an enclosed planter like this one.....darn things weighed around 80lbs each.....took almost 300....my poor back!!.....  Your back? Why aren't the inmates lifting?
Stanley Steamer
« Reply #9 on: June 28, 2012, 07:51:07 PM » |
First time I had seen any molded like that also.......it didn't matter so much as long as you use them in a retaining wall fashion or in an enclosed planter like this one.....darn things weighed around 80lbs each.....took almost 300....my poor back!!.....  Your back? Why aren't the inmates lifting? I did have them carry them over and place them near where I needed them.....I always work harder than my crew....just the way it is!
« Reply #10 on: June 28, 2012, 07:53:23 PM » |
First time I had seen any molded like that also.......it didn't matter so much as long as you use them in a retaining wall fashion or in an enclosed planter like this one.....darn things weighed around 80lbs each.....took almost 300....my poor back!!.....  Your back? Why aren't the inmates lifting? I did have them carry them over and place them near where I needed them.....I always work harder than my crew....just the way it is! You got to learn to delegate Steamer. Train your team and the team will accomplish more. I assume most of your team might not be that willing but I'm sure you can find one or two who take pride in what they can accomplish.
Stanley Steamer
« Reply #11 on: June 28, 2012, 07:55:36 PM » |
First time I had seen any molded like that also.......it didn't matter so much as long as you use them in a retaining wall fashion or in an enclosed planter like this one.....darn things weighed around 80lbs each.....took almost 300....my poor back!!.....  Your back? Why aren't the inmates lifting? I did have them carry them over and place them near where I needed them.....I always work harder than my crew....just the way it is! You got to learn to delegate Steamer. Train your team and the team will accomplish more. I assume most of your team might not be that willing but I'm sure you can find one or two who take pride in what they can accomplish. I let my Groundskeeper be in charge of some of the job.....he's a former Marine.....and does take pride in a job well done.....sadly, he is going to Tech school to learn A/C work.......
