April 01, 2026, 02:42:12 PM
running tail lights in stock light
Topic: running tail lights in stock light (Read 784 times)
pedsman
June 28, 2012, 06:32:23 PM »
Howdy all, hope you are enjoying the summer!! Would like to add some rear running lights right in the stock tail lights, if possible. Any suggestions on manufacturers/products would be greatly appreciated!!
Ride Hard, Ride Safe!!
Fast Black, 99 Standard
Vroom-Vroom!
Re: running tail lights in stock light
June 28, 2012, 07:12:26 PM »
Are you asking about adding running lights in the turn signal housings? Two ways to go here. 1: Get another pair of front turn signals which have dual elements so they'll be on and flash for turning. 2: Buy an Electrical Connections turn signal kit. HDL sells them for about $50. The kit adds a ring of LED red lights inside the lens which are also a brake light. Their wiring makes the running light flash with the turn signal. Go to HDL's website (not OEM) and click on Electrical Connections brand.
pedsman
June 30, 2012, 08:27:30 PM »
thank you for the info...
Mr.BubblesVRCCDS0008
July 01, 2012, 05:00:41 AM »
You can also replace your rear single element sockets with some from auto parts store with dual element sockets. You'll have to pull power from the lis. plate light and make sure you get the replacement socket grounded good.
JaysGone
Delray Beach Florida
July 01, 2012, 05:08:59 AM »
Im relatively new here.
Can some one point me to whatever HDL is??
Thanks guys.
1999 Valk - SOLD
2005 Yamaha RoadStar
FryeVRCCDS0067
Brazil, IN
July 01, 2012, 05:37:18 AM »
Quote from: JaysGone on July 01, 2012, 05:08:59 AM
Thanks guys.
http://www.hdlparts.com/
Dave Ritsema
South Bend IN
Reply #6 on:
July 01, 2012, 07:57:44 AM »
Below is a write up I did on the electrical connection LED kit over 10 years ago. (WOW, has it been that long?)
http://www.valkyrieriders.com/shoptalk/ledturnsignalmod.htm
VRCC 2879
Lake City Honda Warsaw IN
JaysGone
Reply #7 on:
July 01, 2012, 08:45:20 AM »
FryeVRCCDS0067
1999 Valk - SOLD
