April 01, 2026, 02:48:50 PM *
Author Topic: 1-3-5 Shift Pattern  (Read 2569 times)
Sodbuster
« on: June 30, 2012, 05:06:42 AM »
I came across a rider the other day who rode a Valk Trike that said when he rides he only uses 1-3-5 gears because 2 & 4 are just a waste of time. He would double click when he shifted. Ever heard of anyone practicing such a thing ??
I'm guessing he prolly got a little better gas mileage.
VRCC # 30938
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #1 on: June 30, 2012, 05:17:25 AM »
Nope.
But the world is full of weird, and I support his right to be goofy. crazy2 crazy2
Jabba
« Reply #2 on: June 30, 2012, 05:38:08 AM »
Can't see the (if any) gas savings being worth the effort.
I'll admit skipping/jumping gears in my Dodge Cummins diesel/manual when I'm running without a load but, with a load, that ain't gonna happen.
« Reply #3 on: June 30, 2012, 05:38:15 AM »
Nope.
Jabba
+1
9Ball
« Reply #4 on: June 30, 2012, 05:47:24 AM »
Probably has his helmet lined with aluminum foil too..... Shocked
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
JDW365
North Newton, Kansas
« Reply #5 on: June 30, 2012, 06:32:55 AM »
Doesn't Everyone? ??? Roll Eyes Lips Sealed
Raverez
No good deed goes unpunished
Central New York State
« Reply #6 on: June 30, 2012, 06:39:00 AM »
Do that in the truck most of the time. Supposed to save on fuel.
MacDragon
My first Valk VRCC# 32095
Middleton, Mass.
« Reply #7 on: June 30, 2012, 06:42:12 AM »
There are times when I shift 1-2-3 and then if I know I'm not going to be going much faster than that on the road I'm on... I'll double shift right to 5th and cruise from there at around 45 and up keeping the RPMs at 2000-2500.  Is there something wrong with that?
Patriot Guard Riders
« Reply #8 on: June 30, 2012, 06:50:41 AM »
I frequently do the same McDragon. As far gas savings by skipping gears, I seriously doubt that there is much, if any. My 2c.  Roll Eyes
My rides:
« Reply #9 on: June 30, 2012, 07:38:03 AM »
i have enough trouble trying to find 6th to worry about if i skip a gear on the way there 2funny
i have double clicked a few times just to see how the bike handles on hard acceleration onto a highway
« Reply #10 on: June 30, 2012, 07:42:03 AM »
Where are you?
Saw on the TV news that Washington State got a weather hammering last night.
Michael K (Az.)
Glendale, AZ
« Reply #11 on: June 30, 2012, 07:44:47 AM »
Where are you?
I think it was D.C.
« Reply #12 on: June 30, 2012, 07:46:02 AM »
Where are you?
I think it was D.C.
Oh. Thanks.
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #13 on: June 30, 2012, 08:27:59 AM »
Shift?  I just start in 5th. WTH.  Grin Grin
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
« Reply #14 on: June 30, 2012, 08:45:17 AM »
Nothing wrong or weird about that practice. I do it quite often if traffic allows me to wind up the rpm's enough in first. I'll then go directly to 3rd, but do it only if the traffic is moving in such a way I can keep the rpm in the same general range. Then, again if the traffic is such that it can be done effectively I'll jump to 5th on the next shift. If the engine speed is up you're not lugging it nor are you over revving. I don't do it for any fuel conservation, just something I do. Basically, if the situation you're in doesn't call for using each gear, why bother with the extra shifting. Now if I happen to be in a situation that calls for a good twist of the wrist...different story. I'll use every gear in there and wish for one more at the end.
So, tell your friend there's nothing weird or unusual about his shift pattern. It won't hurt the engine or driveline, I've been doing it longer than many have been breathing and have yet to experience engine failure or driveline disaster.  Wink
Michvalk
Remus, Mi
« Reply #15 on: June 30, 2012, 08:54:17 AM »
I routinely skip 2nd and 4th. But then I already knew I am wierd and different Cheesy Shocked cooldude
PAVALKER
Pittsburgh, Pa
« Reply #16 on: June 30, 2012, 09:34:51 AM »
I also frequently skip 2nd and 4th, especially when I want to put my feet up on the forward pegs to kick back and relax.
John
Tropic traveler
Silver Springs, Florida
« Reply #17 on: June 30, 2012, 09:49:32 AM »
I frequently use the 1-3-5 shift pattern and sometimes a 1-2-5 or some variation if I am not in any hurry or no traffic is around. No reason other than it's very easy to do & it saves a teeny bit of wear & tear on the clutch & transmission. The F6 engine is a wonderful torquey beast!  cooldude
'13 F6B red for Kim
Skeeter (Va)
Virginia Beach, Va
« Reply #18 on: June 30, 2012, 10:35:38 AM »
All the time when not hilly.
Life's tough....It's even tougher if you're stupid....        1998 Blk..Valk Std...1971 Honda 750 Four...
Michael K (Az.)
Glendale, AZ
« Reply #19 on: June 30, 2012, 04:40:44 PM »
I skip the clutch often when I'm shootin pics in the twisties. Just gotta be mindful of the revs.
tonyfan70
Apparently they know you?
Central Illinois
« Reply #20 on: June 30, 2012, 05:12:50 PM »
Hell, just leave it 3rd all the time. Should get ya rollin and easily fast enough to lose your DL.
1997 Standard. Original bumblebee tin stored.
1998 Magna 750
2000 POS Sportsman 500
musclehead
inverness fl
« Reply #21 on: June 30, 2012, 08:38:08 PM »
it's called 'progressive shifting'  us big rig guys know it well  cooldude
as far as fuel savings on a two wheeler? I dunno?  Lips Sealed angel
forjj
Luray, VA
« Reply #22 on: June 30, 2012, 09:09:58 PM »
Skip shifting is a "feature" on GM 6-speed transmissions.  It is annoying, but the idea is that it is a fuel saver.  The way it works on the GM is 1-4.  If you ease off the line, and tach it up to a certain range, the computer will lock out 2nd gear, so that when you clutch and shift back from first, it forces you into 4th.  I don't see it as a fuel saver, b/c I wind up gassing it to get the revs back up.  And yes, I do skip a gear or two on the valk from time to time.
2000 Interstate Blue/Silver
2005 Corvette
1989 F250 Diesel
1979 Ford 1100 Diesel Tractor
"I don't know where I'm going, I see no reason in being late"
Valkahuna
DeLand, Florida
« Reply #23 on: June 30, 2012, 09:20:37 PM »
Only if you are a purist! Heck, the Fat Lady has enough torque to shift from 1st to 5th, though I agree with Jabba, it would make me feel a bit weird as well (although I would defend your right to do so!!!)  2funny crazy2
2014 Indian Chieftain
2001 Valkyrie I/S
« Reply #24 on: July 01, 2012, 05:07:41 AM »
BMW auto did a study/test over 20 yrs ago proving that the sooner the car gets into high gear the better mpg. this required higher rpms in lower gears to get to intended cruising speed faster and then being in the high gear.
I do on occasion skip gears depending on the low gear acceleration I did and the cruise speed I want.
skipping gears will reduce clutch wear.
JaysGone
Delray Beach Florida
« Reply #25 on: July 01, 2012, 05:12:29 AM »
Ive been doing the 1,3,5 in almost all my vehicles for years.
Or in 6 speed cars 1,3,6
2 and 4 are a wasted gears.
Heck my Camaro wont let me shift into 2nd............unless your flooring the gas.
      1999 Valk - SOLD
      2005 Yamaha RoadStar
