April 01, 2026, 06:27:05 PM *
Author Topic: 1157 1156 LEDs  (Read 994 times)
Jeff K
« on: July 06, 2012, 05:51:38 AM »
Anyone have any experience with these LED replacements? They have a huge assortment. I want to take some of the load off of my trailer lights. But I want to maintain or increase the brightness.
It currently has 2 5007, 2 1157, and 2 1156 bulbs
« Last Edit: July 06, 2012, 05:59:58 AM by Jeff K » Logged
Sergeant D
So your bike has how many cylinders?
Universal City, TX
« Reply #1 on: July 06, 2012, 05:55:26 AM »
They are good by my experiences.  I bought mine from another recommended source on this board at www.superbrightleds.com for less $.  They are a direct replacement.
Ride safe.
"It's a friggen motorcycle, it's not supposed to be comfortable, quiet or safe. The windnoise is supposed to hurt your ears, the seat should be hard and riding it should make you crap your pants every now and then."
Jeff K
« Reply #2 on: July 06, 2012, 06:24:18 AM »
My question is which ones have people used with success? They have pages and pages of bulbs with varying amounts of LEDs
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: July 06, 2012, 07:37:29 AM »
I get mine at Autozone.  Can't remember the brand.
Marty
« Reply #4 on: July 06, 2012, 07:50:24 AM »
I have a 30 LED 1157 taillight bulb. It's been in there for years. Don't remember how long and no problems.
PAVALKER
Pittsburgh, Pa
« Reply #5 on: July 06, 2012, 07:56:24 AM »
The flat panel lights like described above from Custom Dynamics or Radiantz are good.  I did not have luck with those little bulb replacements that have 10 or 12 leds in, in the same round shape as a bulb... those were cheap and gave off less light than a standard bulb.  In daylight it was not bright enough at all.  A larger panel is needed.  The one in my tail light is from Custom Dynamics I believe, and works great.
Technology might have changed in the last few years tho.....  but when those little LEDs didn't work our for me, I used halogen bulbs... much brighter.  As for taking the load off the trailer.... hope you find some good LED's....  might want to check what the truckers use.
John
« Reply #6 on: July 06, 2012, 08:08:10 AM »
I have also seen 1156/7 led replacement bulbs that looked brighter at night but not in the sunlight.
And leds in turn signals require load equalizers or heavy duty electronic flashers.
Jeff K
« Reply #7 on: July 06, 2012, 09:06:29 AM »
I've got an electronic flasher, so load isn't an issue. I did that when I put the LEDS on the bike.
« Reply #8 on: July 06, 2012, 10:36:27 AM »
I tried some of the cluster led bulbs.
My experience with them was that they seemed bright enough......but only if you looked straight at them.
I've got clear turn signal lenses on my bike.....they simply didn't illuminate the turn signal lens if looked at from virtually any angle......only from viewing directly at them.
The whole point of using lights is to be seen, so I thought them more of a hazard since you can't see them from any side angle and took them out and put the regular yellow bulbs back in there.
The regular bulbs illuminate the entire lens and can be seen from any angle.
