« on: September 03, 2014, 01:46:37 PM » |
« Last Edit: September 03, 2014, 02:05:19 PM by BF »
I can't help about the shape I'm in I can't sing, I ain't pretty and my legs are thin But don't ask me what I think of you I might not give the answer that you want me to
Slvrvalk1
« Reply #1 on: September 03, 2014, 02:18:31 PM » |
Pappy!
« Reply #2 on: September 03, 2014, 04:49:15 PM » |
Have two of the First Gear bags and one of the Wolfman. All of them are absolutely excellent in protection from the elements!
« Reply #3 on: September 03, 2014, 05:00:07 PM » |
Good to hear.
« Reply #4 on: September 03, 2014, 05:59:01 PM » |
Looking around some more, I came across these (again, very similar, but not motorcyce specific). They have a bunch of different sizes. http://www.overboardusa.com/duffels/waterproof-duffels.html
« Reply #6 on: September 03, 2014, 07:44:39 PM » |
I got a D38 Dryspec bag from Twisted Throttle for the Inzane trip. It can go to the bottom of a pool and contents stay dry. Use it on the supervalk, it will not easily fit on an IS backseat (except end to end, thus blocking the trunk from opening). Rigid core holds it's shape full or empty so it does not droop over the bag lids while travelling (perfect for the solo rack). Only negative is that the roll up opening is a bit difficult to load thru, you have to load smaller amounts of stuff, not all your stuff in one big pile. http://www.twistedthrottle.com/dryspectm-d38-rigid-waterproof-motorcycle-dry-bag-in-black-grey-or-orange
« Last Edit: September 03, 2014, 07:47:22 PM by Jess from VA »
NW roller
« Reply #7 on: September 03, 2014, 08:01:51 PM » |
I just use what the call Sea Bag it has magnetic seal and you just roll it up and clip it looks like a duffle bag
Those who won't listen must feel. David B
« Reply #9 on: September 11, 2014, 06:12:13 PM » |
I used to ride with a T Bag set up (vertically) just like that, then I went solo. Discovered that I could travel much easier with the T Bag in the prone position. Top heavy no longer, caught less wind and better rearward vision. Now, I rarely load up the bike for travel, I use my pull behind. The bike is naked and the trailer makes the journey much nicer. Wish I had gone this route years ago.
« Last Edit: September 11, 2014, 06:14:27 PM by Rams »
VRCC# 29981 Learning the majority of life's lessons the hard way.
jimmytee
« Reply #10 on: September 11, 2014, 06:25:30 PM » |
Just remember to keep her in gear on those hills!!!
« Reply #11 on: September 11, 2014, 06:33:37 PM » |
Aw yes, there's another one of those "gotcha" lessons. Your more that welcome to tell that story.
jimmytee
« Reply #12 on: September 11, 2014, 07:09:06 PM » |
Aw yes, there's another one of those "gotcha" lessons. Your more that welcome to tell that story.  OK.  So here we are, Rainman, his wife Diana, Hal, Gavin and Dennis, sitting at McDonalds getting some quick breakfast for out ride home after this year's Inzane. We watch Rams pull up in front of our bikes with his Valk and trailer. He gets off and begins to walk away towards the McDonalds. We're all watching through the window as Ram's whole rig begins to roll down hill and then his bike falls over . There was no way we could warn him.
« Reply #13 on: September 12, 2014, 03:16:05 AM » |
Aw yes, there's another one of those "gotcha" lessons. Your more that welcome to tell that story.  OK.  So here we are, Rainman, his wife Diana, Hal, Gavin and Dennis, sitting at McDonalds getting some quick breakfast for out ride home after this year's Inzane. We watch Rams pull up in front of our bikes with his Valk and trailer. He gets off and begins to walk away towards the McDonalds. We're all watching through the window as Ram's whole rig begins to roll down hill and then his bike falls over . There was no way we could warn him.  Yep, slight downhill grade. Won't deny it. Pulled up, put the kick stand down, key off in neutral. Was off the bike and at least 10 steps away when I heard it fall. Obviously, I didn't hear it start to roll. Several lessons learned that morning. Luckily, no damage to bike.
