February 14, 2026, 03:08:13 AM *
Author Topic: Valve Cover Sealant  (Read 1152 times)
Bob D
Las Vegas, Nevada
« on: March 23, 2018, 11:34:53 AM »
I just adjusted my valves (2001 Standard) and bought a new set of gaskets. My Honda Service manual says to use Three Bond 1521 sealant. Is this specific type really necessary or is there a substitute to avoid an on-line order? I searched previous threads but nothing on valve cover sealant. Thanks in advance!
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #1 on: March 23, 2018, 11:36:40 AM »
Any high-heat sealant will work.
« Reply #2 on: March 23, 2018, 11:42:32 AM »
You only put tiny dabs of sealant on the four square landings, one on each side of the cam at each end the rest of the gasket is installed dry.
SCain
Rio Rancho, NM
« Reply #3 on: March 23, 2018, 11:42:49 AM »
I've never used a sealant on a valkyrie valve cover, removed many and the only thing I have ever used was a a small dab of hondabond or = in the corners. I wouldn't use anything in case they need to come off again for some reason.
My .02
Steve
Bob D
Las Vegas, Nevada
« Reply #4 on: March 23, 2018, 12:01:12 PM »
Thanks for the input. I'll just grab some Hondabond from my local dealer.
« Reply #5 on: March 23, 2018, 04:01:47 PM »
this is all u need
 https://www.permatex.com/products/gasketing/gasket-sealants/permatex-form-a-gasket-no-2-sealant/
No 1 is not flexible so only No 2.
Bob D
Las Vegas, Nevada
« Reply #6 on: March 24, 2018, 07:08:05 AM »
Thank you!
