February 14, 2026, 03:10:02 AM *
Author Topic: Hinge on an IS trunk  (Read 1068 times)
NighthawkVTX
Gainesville, Fl
« on: March 28, 2018, 08:25:43 AM »
The other day I noticed that 2 scews rom my trunk hinge had disappeared.
No big deal I thought.
I pulled the remaining screw and founf it was a m6.
Well I tried to screw in two new screws and found they dont fit... by alot.
Does anyone one know the screws that will fit?
If at first you don't succeed, then perhaps skydiving isn't for you
« Reply #1 on: March 28, 2018, 08:39:07 AM »
Take the one good one to ACE hardware and match it up
Paladin528
« Reply #2 on: March 28, 2018, 10:32:27 AM »
it is likely one of the following  There is one short one and 2 long ones per hinge.
SCREW, PAN (6X8)
93500-06008-0G
SCREW, PAN (6X20)
93500-06020-0G
NighthawkVTX
Gainesville, Fl
« Reply #3 on: March 29, 2018, 10:43:35 AM »
Well I unscrewed a screw from the opposite hinge.
The problem is now I cant get the screw to  thread. Im guessing there must be a nut on the other side of the wall.
Im thinking of taking the speaker out and looking at the inside.
Uhhhh anyone knowhow to temove the speakers?
« Reply #4 on: March 29, 2018, 11:11:08 AM »
Yeah, each hinge has 2 nuts under the speakers.
NUT, FLANGE (6MM)
94050-06070
they go to
SCREW, PAN (6X20)
93500-06020-0G
You'll need these also
COLLAR, RADIATOR MOUNTING
19052-KV0-000
« Last Edit: March 29, 2018, 11:14:21 AM by Hook#3287 » Logged
NighthawkVTX
Gainesville, Fl
« Reply #5 on: March 29, 2018, 11:26:49 AM »
Ahhhhhh they makes sense. Now just to remove the speakers without breaking anything
