January 01, 2026, 01:38:11 AM *
Author Topic: LED headlight bulb  (Read 2324 times)
Motodad71
Westerville OH
« on: March 30, 2018, 02:37:23 PM »
Yes I am a new guy, and yes I did a search......not much new info I could find. So......I have found these 2 bulbs which I am curious as to if any of you currently use/used and any input?
https://www.superbrightleds.com/moreinfo/motorcycle-high-beam-and-low-beam-headlight-bulb/motorcycle-led-headlight-kit-h4-led-headlight-conversion-kit-with-aluminum-finned-heat-sink/4316/9637/#tab/Overview
https://www.superbrightleds.com/moreinfo/motorcycle-high-beam-and-low-beam-headlight-bulb/motorcycle-led-headlight-conversion-kit-h4-led-headlight-bulb-conversion-kit-with-compact-heat-sink/3930/8566/
1997 yellow/black Valkyrie standard "Thor"
Gideon
Indianapolis, IN.
« Reply #1 on: March 30, 2018, 02:59:01 PM »
Replaced Head Light Bulb with Pathfinder LED 4H 6000K Bright White LED Bulb, Part No.H4SFX.
All can say WOW!
It is bright and easy to install.
Motodad71
Westerville OH
« Reply #2 on: March 30, 2018, 06:00:35 PM »
Awesome good sir thanks for the info, will for sure be checking that out.
« Reply #3 on: March 30, 2018, 09:18:10 PM »
I found it posted here.
https://www.jpcycles.com/product/901-491/pathfinderled-h4-6000-lumens-led-bulb
But $70 USD and needing 2 for the IS, costs a lot.
Savago
Brentwood - CA
« Reply #4 on: March 30, 2018, 09:57:31 PM »
I like LED lights, as a matter of fact have Rigid Industries lights mounted in 2 of my bikes.
But for the valkyrie, none. The I/S lights (got 55/65W bulbs) are one of the best I've seen in any bike and the fog lights (35W) work really well.
The reason to go LED would be to have more lumens with less heat? (i.e. in a standard)
Motodad71
Westerville OH
« Reply #5 on: March 31, 2018, 04:45:11 AM »
For me it is also the obvious less amount of current draw on the wiring system and starter switch assembly, and the LED technology is just getting better and at times cheaper. I will get a switched/un-switched power hub eventually, but the LED headlight bulb will likely be one of my first farkles.
« Reply #6 on: March 31, 2018, 11:31:51 AM »
the best to get
https://www.cyclopsadventuresports.com/7000-Lumen-H4-LED-Headlight-Bulb_p_169.html
https://www.cyclopsadventuresports.com/3800-Lumen-H4-LED-Headlight-bulb-_p_83.html
Psychotic Bovine
New Haven, Indianner
« Reply #7 on: March 31, 2018, 01:10:45 PM »
I will 2nd that.  I have them in my Valk and Scrambler (which had a horrid headlight).
"I aim to misbehave."
Motodad71
Westerville OH
« Reply #8 on: April 01, 2018, 08:32:14 AM »
Thanks for the info y'all......
Kirknik
Still running against the wind
Winnipeg, Mb Canada
« Reply #9 on: October 24, 2018, 05:32:42 AM »
Are these H4 led bulbs basically plug and play into a tourer headlight? Seems like the ones I want .
Thanks in advance.
« Reply #10 on: October 24, 2018, 09:34:33 PM »
Which bulb is required? If it is an H4, then the H4 LED will be just a OEM replacement and work.
Colin
My old job
Orba, Spain
« Reply #11 on: October 24, 2018, 09:48:10 PM »
Thanks in advance.
The one I fitted is reasonably plug and play. You have to take off the rubber boot, it will not fit back (well it wouldn't on mine). The LED bulb I fitted comes in two parts, the H4 mounting plate and the bulb itself. I fitted the mounting plate first and locked it in place with the lever catch. I then mounted the bulb in the H4 mounting this was a bayonet fit as I twisted it into place I had to feed the bulb heatsink fins over the mounting clip by pressing down on the clip and that was it. Route the wire and LED control box inside the headlight and that was it. Sounds more complicated than it was. I have to swap it back to a conventional bulb every time I take it for its technical inspection as LED lights are not homologated for our age of bike (crazy but the law here in Spain) so I do the swap fairly frequently and it takes less than 5 minutes each way including unscrewing the headlight shell.
Colin
VRCC Espana
My Bumble Bee re-build
