February 14, 2026, 03:10:02 AM *
Author Topic: Signal Boss Install Question-  (Read 1046 times)
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
« on: April 02, 2018, 01:45:20 PM »
Well, I started to install the Signal Boss harness on my 99CT...got it all connected as per instructions...but I see two more wires that are not mentioned in the install instructions...they were a Pink and a Purple wire with bayonet type connections that are insulated...where do they go???...I don't see any pink or purple wires on my bike headlight wires...I installed the springs and everything properly...powered up...the turn signals stayed on...so I proceeded to section 4 vii to cancel the Auto Cancel Configuration...noticed I had No brake lights when I tried the brake lights...Is there something I'm missing??? I have a switched Cobra Highway Bar on my bike...but I just can't see where to hook up these two wires(Pink and Purple)...the good thing, I found that my choke cable is about to brake, so I ordered one that will be in on Wednesday...I would appreciate any help if you know what I did/did not do...!!! Thanks...!!!
« Last Edit: April 04, 2018, 07:13:45 PM by mrgeoff » Logged
mrgeoff/SANDMAN
mrgeoff
Augusta, GA.
« Reply #1 on: April 04, 2018, 07:12:14 PM »
Sorry...I put SmartBoss but meant to type Signal Boss...!!!
mrgeoff/SANDMAN
Ramie
2001 I/S St. Michael MN
« Reply #2 on: April 05, 2018, 05:28:51 AM »
Send a PM to Jersey if you have questions.
http://www.valkyrieforum.com/bbs/index.php/topic,96114.0.html
mrgeoff
Augusta, GA.
« Reply #3 on: April 05, 2018, 06:53:29 PM »
I did send Jersey a Message...Thanks....!!!
mrgeoff/SANDMAN
