February 14, 2026, 05:00:29 AM
Hard Carb Insulators
Topic: Hard Carb Insulators (Read 855 times)
Forge
San Antonio, TX
April 26, 2018, 06:08:40 AM »
I have cleaned and resealed my carbs with Redeye seals. I also purchased new runner to head O-rings. I am wanting to reinstall the carbs, but I noticed that my carb to runner boots are dry and hard. I know the correct answer is to replace them, but in the meantime, can I use a fuel resistant sealant to make sure that I don't have any vacuum leaks? How about Permatex Permashield? Has anyone done this and what did you use?
Re: Hard Carb Insulators
April 26, 2018, 06:36:14 AM »
All of mine are pretty stiff. They are thicker than normal carb boots on most bikes. I would just make sure you have everything installed correctly and tightened.
da prez
Wilmot Wi
April 26, 2018, 06:48:45 AM »
Food safe silicone spray will help. If they are still flexible and not cracked thru , they are usable. The spray will soften and make them slide on easier. Be sure to recheck the clamp screws after you install the tubes.
da prez
