February 14, 2026, 10:25:22 AM *
Author Topic: Just completed a run of permanent installed lift adapters, both types  (Read 3480 times)
« on: April 28, 2018, 06:30:40 PM »
"Both types" being, a version for belly tank equiped bikes, and the other for without BT.  These are all powder coated black since most everybody asked for that.  Recall, these are lightweight (shipping wt 4# - less than my S&W 500mag revolver!), cantilever design that does not reach up into the swingarm area, so anything you have up there doesn't conflict.  Made with thickwall 3/4" steel box tubing.  Also these are version 2.1 that uses large bolts that pull the adapter up tight to the bottom of the engine, and has shims to closely support the engine where it steps up some (not pictured below - also the new hot-forged bolts not shown).  These are a great tool you can install and forget until you need to lift the bike - say at Inzane you need to change a tire, or a bearing went out.  Any bike lift will now lift the bike w/o concern for the CG living at the void aft of the engine.
$67 + priority mail of $15.  (East coast generally costs me about $18 but I'll cover the extra)
Here's a post from before that had pictures - edited a little:
The adapter for stock bikes:
The adapter for belly tank equipped bikes:
The belly tank adapter installed on my Jade:
The no-belly adapter installed on my George:
I should mention, I am talking about the R&M Works belly tank here.  I don't know of any other brand - to my knowledge, they are the only belly tank available.  This is for the standard version, not the smaller one for 6-6 pipes (Cobras I think).  Haven't tested the adapter with that tank.
Note, the 1/2" tubing locations is not a mistake.  The belly tank is asymmetrical.
Just call it in or use paypal to my email valkstuff@horseapple.com, contact info at website http://www.horseapple.com
« Last Edit: April 29, 2018, 09:10:22 AM by MarkT » Logged
Paladin528
« Reply #1 on: May 01, 2018, 06:12:40 AM »
ship to Canada?
« Reply #2 on: May 01, 2018, 07:00:58 AM »
Yep.  What's your postal code, I'll get the cost.
Paladin528
« Reply #3 on: May 02, 2018, 09:07:27 AM »
L7G6G1
« Reply #4 on: May 02, 2018, 11:01:30 AM »
To Toronto area, USPS quotes $46.65. Due to the size apparently.  Fedex quotes $32.98.
Savago
Brentwood - CA
« Reply #5 on: May 02, 2018, 12:49:16 PM »
This is something that I have being looking for my I/S in the last 4 years... and buying from a forum buddy would be even better.
A few questions:
a) How hard is the install? (being 1 'wrench' for an oil change, 3 wrenches for an alternator change and 5 for a carb rebuild?)
b) Does it require any special tools? (e.g. impact tools, etc)
c) Does it require a lift/jack to install? Or would a wheel chock do the job?
« Reply #6 on: May 02, 2018, 02:46:47 PM »
A few questions:
a) 3/4" or 19mm wrench, any type.  Two "L" bolts to insert, 2 washers, 2 nuts to tighten.
b) No.  Torque wrench if you want but just a good twist around 25 ft/lbs is good.  Use blue loctite if you want to.
c) No. Just lay on your side alongside the bike.  Rt side might be easiest.
WoodyFL
Ocoee, Fl
« Reply #7 on: June 03, 2018, 10:45:56 AM »
Mark,
PM sent.
Bob
2000 Blue/Silver I/S
Ocoee, FL
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
« Reply #8 on: June 03, 2018, 07:11:47 PM »
I have one installed on my Liahona, 99 CT...Easy to install and a blessing to use....!!!
mrgeoff/SANDMAN
Offdibb
UK
« Reply #9 on: June 03, 2018, 11:46:20 PM »
Hi Mark,
Just what I'm looking for - would you post a stock one to UK?
Thanks.
« Reply #10 on: June 04, 2018, 06:34:50 AM »
Yeah I'll send it anywhere if you cover the shipping.  Just provide an address so I can get the shipping cost.  Maybe send that to my email so you don't put it on this public forum. valkstuff@horseapple.com
Offdibb
UK
« Reply #11 on: June 04, 2018, 05:32:14 PM »
Thanks Mark - PM sent.  cooldude
Forge
San Antonio, TX
« Reply #12 on: June 19, 2018, 06:29:11 PM »
I think I need one of these for my stock Interstate. PM Sent!
« Reply #13 on: June 19, 2018, 08:37:04 PM »
I'm still on the road from Inzane.  Taking a roundabout route to visit family in 3 states. I'll be back in the shop the end of next week.
