February 14, 2026, 06:51:22 AM *
Author Topic: Fender washer mod  (Read 1109 times)
muscrat
My Shrink
Tilbury On, Southern most area of Canada
« on: May 07, 2018, 09:34:54 AM »
Looking for any additional info on the fender washer mod when installing a CT as just eyeballing it looks like a 1/2" difference from left to right and does it matter, thanks for any info.
Ken in S/O
So Many Roads, So Little Time !
vanagon40
Greenwood, IN
« Reply #1 on: May 07, 2018, 11:15:52 AM »
I do not remember how many (one or two each side), but I used the same number of washers on each side. The tire is probably not perfectly centered under the fender, so it is probably possible to use a little less (or none) on one side. Size of the tire will make a difference as well.
« Reply #2 on: May 07, 2018, 01:44:11 PM »
As I did this a looooooonnnggg time ago, my memory is fuzzy on this, but it seems my fender was not centred, and I used three or more washers on one side to centre it.  Because of distance ratios, I think adding one washer will move the fender twice the thickness of the washer or thereabouts.
« Reply #3 on: May 07, 2018, 04:56:37 PM »
No need to do both sides, just the right side to get the clearance. I'd sure check first, you may not need it, most of the time just removing the nut cage is all that's required.
muscrat
My Shrink
« Reply #4 on: May 07, 2018, 06:56:44 PM »
Thanks again to all, hope to get my first CT ride by the weekend :
« Reply #5 on: May 07, 2018, 08:17:40 PM »
Unless you are hitting the fender, there is no reason to play with it.
« Reply #6 on: May 08, 2018, 07:37:56 AM »
Maybe not functionally, but I am a draftsman, and things like plumb/level and symmetry MUST be fixed or I'll develop a tic.
0leman
Klamath Falls, Or
« Reply #7 on: May 08, 2018, 07:46:42 AM »
My first CT was a square sided one.   I did the back nut cage before mounting it.  It cleared.  But noticed that with two up, it rub the front one (right side only).  Remove that cage.  Didn't help. Ended up doing the washers.   Real pain as I have a IS, had to remove the trunk to move the side bar.  Used three washers it I remember correctly.
the other 2 CT's have not had that issue, more rounded shoulders.  I have not removed the washers, should.
Mount the tire (after removing the rear cage), take her for a ride.  If you rub, then do the washer thing.   I didn't rub till we did the two up.  So if you do two up.  Make sure you do that test.
muscrat
My Shrink
« Reply #8 on: May 09, 2018, 06:10:35 PM »
Thanks again to all, saving all reply's and will do a few test rides to see how things go now that I know what to look for.
Ya'll rock, muscrat.
muscrat
My Shrink
« Reply #9 on: May 10, 2018, 05:25:17 PM »
Well the Champiro is mounted all went well, used WD40 liberaly and it seated at 39 psi. Thanks again for all the tips as usual, what a great forum.
Ken (muscrat)
