February 14, 2026, 08:39:23 AM
Clutch question?
Topic: Clutch question? (Read 1088 times)
Paladin528
Clutch question?
May 18, 2018, 04:33:44 AM »
I need to pull my clutch off and am wondering if it’s possible on the side stand. I can’t put it on the jack since the adapter blocks the cover. Is it doable or should I find someon with a lift and chock? I have never pulled the clutch on a Valk.
indybobm
Franklin, Indiana VRCC # 5258
Re: Clutch question?
May 18, 2018, 06:22:42 AM »
The answer is no. What you can do is jack the bike up, place jack stands under the front crash bars and rear bag supports and then remove the jack and jack adapter. If you have a Standard, then maybe put the appropriate stack of wood under the rear tire.
So many roads, so little time
VRCC # 5258
garyheskett All 49 x 3 st.louis
St. Louis, Missouri
May 18, 2018, 08:38:35 AM »
The sidestand has to come off to get the clutch cover off. The kickstand can be quite difficult to get those two bolts off. Mine were real tight, had to go get a longer "cheater bar". There are 3-4 bolts on the clutch cover that are somewhat difficult to get to. What's wrong with the clutch?
Avanti
Stoughton, Wisconsin
May 18, 2018, 09:01:52 AM »
If you have access to an engine lift, remove the seat and use lift straps on the top of the frame under the seat. You can pick up the entire motorcycle using this method to any height you need. I always tie off the handle bars to keep them facing straight forward. You may also want to use a third point to make balancing more effective.
Paladin528
May 18, 2018, 10:52:17 AM »
That’s what I thought.
The clutch is making a nasty sound when engaging until the engine is hot. I am thinking the damper plate might be going. The PO apparently installed a Barnett clutch due to the original failing. I am not sure why it failed with under 30k on it. I would like to pull the clutch pack and see what’s up.
indybobm
May 18, 2018, 12:37:08 PM »
Remove the slave cylinder and grease the pushrod (clutch lifter rod).
VRCC # 5258
Valkpilot
What does the data say?
Corinth, Texas
Reply #6 on:
May 18, 2018, 04:12:07 PM »
Quote from: Paladin528 on May 18, 2018, 04:33:44 AM
http://www.valkyrieforum.com/bbs/index.php/topic,20870.0.html
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
