February 14, 2026, 08:37:34 AM *
Author Topic: Problem solved!  (Read 1389 times)
Valkrocket
Murrells Inlet, SC: formerly Plymouth, MA
« on: May 19, 2018, 07:01:50 AM »
A big shout out to Big BF who knew instantly what the problem was and advised me how to fix it. cooldude
The complete write up is on Big BF's facepage with pictures if any of you guys are interested. My pics don't post well here. I knew it wasn't an air issue like some insisted. Ricky -D led me in the right direction and got me thinking (I surprise myself when this happens)  Wink when he mentioned a "loafing" cylinder and the need for a carb sync.  Thank you Ricky D. After that I started looking around the carbs and throttle drum area. Took some pics. That's when BigBF (also known as the Valk Whisperer) led me to my solution.  Thank you to all that tried to help. This fix should be posted somewhere as it is not the common popping/backfiring scenario posted on this board. The sad thing is Today is the last day of Bike Week here in Myrtle beach and it's pouring out. First Bike week I've missed in 15 years. But soon...………………… I ride cooldude
Glide-on>>>>>>>>
indybobm
Franklin, Indiana VRCC # 5258
« Reply #1 on: May 19, 2018, 07:42:53 AM »
For some reason when I checked BigBF's FB page it does not show anything past April 20th. I hate FB!
So many roads, so little time
VRCC # 5258
Fla. Jim
« Reply #2 on: May 19, 2018, 09:07:00 AM »
For those of us not into Facebook could you give a brief synapse of what you fixed?
Harryc
Sebastian, Fl
« Reply #3 on: May 19, 2018, 09:15:36 AM »
Don't see anything related to this on BigBF's page.
Valkrocket
« Reply #4 on: May 19, 2018, 11:19:16 AM »
Not sure why some of you can't see the posts on his page. Here is the link I use. https://www.facebook.com/search/top/?q=bigbf%20valkyrie%20motorcycle%20shop
For those that can't see the page. Here goes my story (minus pictures)A few years ago I had a local shop clean my carbs and instal the larger slow jets for me. I also used the same shop to have a new set of SS throttle cables installed. Sometime there after my throttle play felt tight, I thought it was probably a cable adjustment. Adjusting helped some but no real snap back when releasing it. I lived with that, never real happy and blaming the ss cables for too much resistance. Then about 2 weeks ago I had a massive gas leak coming from my fuel rails. I had had this happen before and figured they would swell up and stop leaking. They never did. It was time for me to act on this. I had lost my faith in the cycle shop so decided to do it my self. After reading every possible post on the subject I ordered the kit fromred eye and then started tearing sown to the carbs from the inside. I decided to use the "slide back the #5 and #6 carb method to access the fuel and air rails. Worked like a charm. Don't remember who posted that method, but it sure saved me from taking the whole carb assemby apart.  I buttononed everything back up, started her up and found the throttle way worse then before I had to manually turn the throttle back and forth. Not good. Then she started popping at idle. When I gave her some throttle she popped more at a faster rate. After searching for that elusive air/vent leak and coming up empty and adjusting and lubricating the hell out of my throttle cables, I was out of options. :'( I felt like maybe she needed a carb sync, after all she is going to have her 20th birthday next year and has never had her carbs synced. I noticed a post from Ricky D regarding what he called a loafing cylinder that would require a carb sync. So I thought I'd do a carb sync.....only I don't own a gauge. So I thought I might start fiddling with the carb adjustment screws a little toi see if I could reduce the popping and backfiring. My first look at the springs told me something was wrong. Shocked I took pictures of what they looked like and posted them on Big BF's facepage. He confirmed that that was indeed not the way the springs should look. The upper spring on the 5 and 6 sync screw had migrated over the tab of the carb (here's where I wish you could see my pics). Apparently the cylcle shop I used did not reassemble my carbs correctly and I made the situation worse, unbeknownst to me, by moving the carbs back and forth to change out my 4 sets of o-rings. Bill told me how to remove the spring without loosing it. Turn the carb screw out until it bottoms out then work that little bugger free, all while holding the throttle at WOP. Not as easy as it sounds and you need tiny little hands to get the MF back in the correct position. After struggling with it, I finally won the battle. Skinned knuckles and all. Got 'em both in correct position. Started her up and.............. she kept stalling(I had flooded her by holding the throttle wide open while I installed the springs. I could smell it.  I waited 30 minutes and she fired right up. Throttle was like the day I bought her snapping right back. No popping or backfiring. She smells like she's burning rich, but that's either because she is in dire need of a carb sync (Bill is coming to see me this fall I think and said he would take care of it) or still got some extra gas in the carbs from my operation. Now if I could only ride. The Valk Whisperer came through for me from 2000 miles away cooldude Smiley Smiley  Thanks to all that post solutions. Backyard mechanics like me really appriciate the info. I hope this post helps some one out in the future and they don't have to go through the anguish and frustration I went through.
Sorry for the long post.   Glide-on>>>>>>>>>>>>>>>>>
Glide-on>>>>>>>>
