February 14, 2026, 08:39:18 AM *
Author Topic: kick stand lean  (Read 1536 times)
slider
mulberry arkansas
« on: May 20, 2018, 12:18:55 PM »
got a more  lean than I like     any fix  ??
a proud navy veteran
Harryc
Sebastian, Fl
« Reply #1 on: May 20, 2018, 12:38:40 PM »
Do you weld or have access to a good welding shop? Put a shim under the stand and vary height until it is how you like it. Measure the shim thickness at that point. Take the side stand off the bike and take it to a welder and ask them to weld a piece of hardened steel to the bottom foot of that thickness. With that said, check the side stand cross member and mounting points for straightness and fasteners for tightness. There was a company (Rivco) that used to make thick screw-on pads for this purpose for our bikes, but they are no longer made. This is a common problem for guys who go dark side on rear tires, but again it is not unheard of for the cross-member to bend, so check it.
« Last Edit: May 20, 2018, 01:02:38 PM by Harryc » Logged
« Reply #2 on: May 20, 2018, 01:55:34 PM »
I saw a post awhile back from MarkT, danged if I can't find it right now.  Anyway, he designed a handy dandy kickstand pad to fix that lean.  Contact him for the details.
WintrSol
Florissant, MO
« Reply #3 on: May 20, 2018, 02:12:55 PM »
Just be aware that, if you stand it up too much, if the rear tire goes flat to the rim, it could roll over on its right side, especially is the right side is down slope.
Harryc
Sebastian, Fl
« Reply #4 on: May 20, 2018, 03:27:08 PM »
Thank-you. I thought I saw that too. Mark will be along shortly if he wants to sell some stuff. Wink
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #5 on: May 20, 2018, 05:40:32 PM »
http://www.valkyrieforum.com/bbs/index.php/topic,100297.0.html
« Reply #6 on: May 20, 2018, 10:01:55 PM »
Now that's funny.  Houdini already put up the link.  You can call in if you want at 720-851-8455 or email at valkstuff@horseapple.com.  That's also the paypal registered email.
slider
mulberry arkansas
« Reply #7 on: May 22, 2018, 07:44:31 AM »
thanks  all!!!
BigM
« Reply #8 on: May 24, 2018, 07:11:11 AM »
Drill a hole put a carriage bolt in and rubber pad btm of flat part of stand. And a stainless castle nut on top of stand and bolt. Cheap easy fix. Works great. Kickstand sits on the rubber. And dont even see it down or up.
Paladin528
« Reply #9 on: May 24, 2018, 08:47:19 AM »
I have one that also doubles as a load spreader.  Lessens thelean and I can park on dirt and gravel without issue.
« Reply #10 on: May 24, 2018, 11:58:06 AM »
here is my low cost fix
http://www.valkyrieforum.com/bbs/index.php/topic,93955.0.html
Mapper
Montclair, VA
« Reply #11 on: May 24, 2018, 02:53:00 PM »
Let some air out of your tires...  Wink
