February 14, 2026, 08:39:24 AM *
Author Topic: Replacing Indicator Bulbs  (Read 1151 times)
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
« on: May 20, 2018, 08:25:12 PM »
Just wanting to be sure...I have to change out a burnt out bulb for the turn signal indicator. I wanted to know if I can remove the lens cover and then the bulb, without having to get inside the Headlight Housing...??? Just pry the lens cover off...???
mrgeoff/SANDMAN
Disco
Republic of Texas
« Reply #1 on: May 20, 2018, 09:33:55 PM »
Yes, just remove the lens and then the bulb.  The early lenses have two screws on their faces.  The later lenses have one screw at the 6 o'clock position and a tab.  If you pry either style lens without removing the screw(s), you'll break it.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
LB
2003
Upstate South Carolina
« Reply #2 on: May 21, 2018, 04:11:19 AM »
No, you have to go inside the headlight assembly.
« Last Edit: May 21, 2018, 04:13:42 AM by LB » Logged
« Reply #3 on: May 21, 2018, 04:11:54 AM »
I believe he is talking about the lights ON the headlight bucket. And I think k you have to do it from inside
Disco
Republic of Texas
« Reply #4 on: May 21, 2018, 06:14:38 AM »
Thanks, guys.  My mistake.
78 CB550K
mrgeoff
Augusta, GA.
« Reply #5 on: May 21, 2018, 08:40:30 AM »
Thanks...I will remove the headlight first and get back there and find any screw on the inside...Going to replace all while in there...!!!
mrgeoff/SANDMAN
« Reply #6 on: May 21, 2018, 09:17:13 AM »
Just remove the ring and bulb from front of the bucket. Then unstay the wire bundles and move them out of the way. You don't want to remove the whole bucket
mrgeoff
Augusta, GA.
« Reply #7 on: May 21, 2018, 03:04:34 PM »
Found out that I just had to remove the three idiot light covers and remove the bulbs...in doing so, I had one of the bulbs break and I can't seem to get the remaining part of the bulb out of the socket...I removed the complete harness and boots from the Headlight housing...these small bulbs are a pain to remove....is there a special tool to remove them...???
mrgeoff/SANDMAN
Jruby38
Oxford Mass.
« Reply #8 on: May 21, 2018, 05:07:30 PM »
I think they are a type 37 bulb. Original is marked 3 watt. Does anyone know if there is a brighter watt replacement? I find it hard to see neutral in bright sunlight. I cant find any.
« Reply #9 on: May 21, 2018, 05:24:21 PM »
Some have went to led for brighter bulb.
Jruby38
Oxford Mass.
« Reply #10 on: May 22, 2018, 12:53:29 AM »
Thanks Meathead. Do you know the part no. for the LED?
Kunkies
Charlotte, NC
« Reply #11 on: May 22, 2018, 02:19:49 AM »
Would these work?
https://www.ebay.com/itm/2x-T5-LED-Lamp-37-73-Wedge-Dash-Gauge-Cluster-Instrument-Panel-Light-Bulb-70-74-/160882097278
« Reply #12 on: May 22, 2018, 03:24:00 AM »
The ones Kunkies sited are correct. I think Napa and such has them in stock.
