February 14, 2026, 08:51:56 AM *
Author Topic: Rostra cruise install on Tourer - VSS from ECM/coil line? Daniel?  (Read 1057 times)
« on: May 25, 2018, 10:32:47 AM »
I understand the Rostra is made by the same outfit that makes the Audiovox, which reportedly can use a signal from the ECM/coil lines for the VSS signal.  Likely can use the same line?  Daniel, you mentioned this before - did you use such a line with your Audiovox CC?  I can guess but I'd rather avoid a "smoke test".  I have the magnets and sensor but don't want to glue them on my newly powder coated wheels, and have to deal with that on a tire change/drive service.  Also, if you did this, got a starting point for the dip switches?  Anyone have these answers?
Thanks.
« Reply #1 on: May 25, 2018, 12:06:31 PM »
I have the magnets and sensor but don't want to glue them on my newly powder coated wheels...
The magnets used by MC Cruise's system fit inside the hex sockets of the left front brake disc mounting screws, and are held by magnetic force, not adhesive...just to put another idea in your head, if it isn't there already.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #2 on: May 25, 2018, 02:15:40 PM »
Hey Mark give me a call I just finished putting the Rostra cruise control on my Standard and another one on my interstate
918-720-5444 Bob The Attic Rat
mrtlc
Elroy WI
« Reply #3 on: May 25, 2018, 05:22:40 PM »
Hey Bob  The peanut gallery wants to know!!!
99 Interstate 1500
89 Goldwing sidecar 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
« Reply #4 on: May 25, 2018, 05:24:35 PM »
Yeah Bob just told me about that on the magnets.  However the ones I got are way too big.  So I JBWelded them to the rotor out by the spokes - that gives about 7760 PPM, at position 10 of 16 on their pulse range.  After they set up I'll repaint the disc so they disappear.  The black on the rotor is paint, the color on the wheels is powder.
BTW Bob also says, no can do using an ECM / coil signal for the VSS input.
« Last Edit: May 25, 2018, 05:26:34 PM by MarkT » Logged
mrtlc
Elroy WI
« Reply #5 on: May 25, 2018, 07:44:13 PM »
Thanks Mark
99 Interstate 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
