November 14, 2025, 04:31:22 PM *
Author Topic: Right front turn signal not working, fast blink  (Read 951 times)
cogsman
Newmarket, Ontario, Canada
« on: June 15, 2018, 03:25:39 PM »
Hi All,
So as the subject says, all my turn signals are working properly except for my front right which is not coming on.
The turn signal indicator, however, blinks rapidly when I select right turn. Blinks normally when I select left turn.
Is this a signal of a burnt out bulb or something wrong in the bucket?
I am assuming Honda engineered a message into that fast blink...
Andy Cote
Windham, Maine
« Reply #1 on: June 15, 2018, 03:33:36 PM »
Hi All,
Burnt out or loose bulb.  Only one bulb working does not provide enough resistance for he electro-mechanical flasher to work normally.  Same thing will happen in a car.
2015 Goldwing, basic black
Previously: 2000 Valkyrie Interstate, 1997 Valkyrie Standard, 1988 GL1500, GL1200 Standard, GL1200 Interstate and many other Hondas
john m
The Fly
UK
« Reply #2 on: June 15, 2018, 03:42:24 PM »
Hi have you had the bulbs out lately, sometimes if you put them back in the wrong way around they will flash quickly as they get the wrong input as they have two terminals. just a thought.
cogsman
« Reply #3 on: June 15, 2018, 07:23:15 PM »
It was fine up until that day and I hadn't messed with it in over a year. If this points to a bulb issue I will go ahead and undo the assembly and check and/or replace the bulb. Thanks folks!
Valkpilot
What does the data say?
Corinth, Texas
« Reply #4 on: June 15, 2018, 07:49:02 PM »
Could be front or back on that side, but easy to check.  Put the signal on and then walk around the bike and look.  One won't be flashing.
And easy to get to.  The lenses come off.  Either two screws through the front of the lens, or one screw on the bottom side of the lens, depending on year.
« Last Edit: June 15, 2018, 07:53:54 PM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
cogsman
« Reply #5 on: June 16, 2018, 09:54:51 AM »
Pulled the bulb which wasn't working. Filament looks fine and I can't hear anything clinking inside when i shake it...
RonW
Newport Beach
« Reply #6 on: June 16, 2018, 10:18:43 AM »
Did you try twisting and pushing it back in the socket to see if it works? Last night, my brake light wasn't working, so I pushed/twisted it back into the socket, and then the brake light started working again. It had manage to loosen itself. Oddly not enuff to affect the running light (low-filament) though. You didn't mention, but if your running light was also out in your right-front signal, the socket might be defective. Take the good bulb from the Left-front signal and plug it into the Right-front signal. Also, plug the original Right-front bulb into the Left-front socket as a double test.
2000 Valkyrie Tourer
bassman
« Reply #7 on: June 16, 2018, 10:19:44 AM »
Swap it with the working bulb from the other side or replace with a a known good bulb?  Put non-working bulb in the other side that is working?
cogsman
« Reply #8 on: June 16, 2018, 02:28:09 PM »
Did all the troubleshooting you suggested. Finally pulled the bucket and sure enough it was a loose wire; the connector was seated fine but the crimping must be coming loose. I'll have to try and find that kind of connector at Radio Shack. Or the Source or whatever they're calling it these days lol.
Thanks for your help everyone, I jiggled the wire, added some electrical tape, and positioned the flexible bracket to take the strain off of the wire. It works now. No replacement necessary.
« Reply #9 on: June 16, 2018, 03:14:01 PM »
I believe Honda uses a 3.5mm blade. Never did find them local. Below is 2 online companies that have them.
This one is also the link for a solenoid repair connection, other wise the GW Honda one is fine too.
http://www.cycleterminal.com/solenoid-connectors.html
http://www.vintageconnections.com/
