February 14, 2026, 10:25:33 AM *
Author Topic: Normal or not?  (Read 1290 times)
Harryc
Sebastian, Fl
« on: June 16, 2018, 04:49:26 PM »
I have a '97 Valk Tourer with 6 into 6 Cobra exhaust, not jetted. A few times recently I've had to give her full throttle to get to the head of a group ride to let the lead rider know I needed gas or whatever. A couple of my friends said they smelled raw fuel when I blew by them. Mind you I did have the throttle cracked wide open. Normal or not?
« Last Edit: June 16, 2018, 04:53:54 PM by Harryc » Logged
« Reply #1 on: June 16, 2018, 06:02:31 PM »
No one ever told me they smelled gas when I had the Cobras on. Mine did run rich until I changed OEM air filter to K&N
« Reply #2 on: June 16, 2018, 08:45:42 PM »
At how many miles?
Leathel
New Zealand
« Reply #3 on: June 16, 2018, 09:53:07 PM »
I have been told that in the past, When the float level was out, if I did some low rev travel for a while it would start to flood a little and those following could smell petrol
  My bike is still rich mid revs but I have not been told it smells of raw petrol for a while.....but it may still at times?
Harryc
Sebastian, Fl
« Reply #4 on: June 17, 2018, 03:10:52 AM »
@Bighead, 36K miles.
Harryc
Sebastian, Fl
« Reply #5 on: June 17, 2018, 03:13:11 AM »
Float level is a possibility. I did what you did when you rebuilt your carbs though...used the K&L float needles.  I am leaning toward just putting this bike back to stock. The pipes sound good but that's about it as far as any type of advantage. They pop on decel, turn blue, drone on long rides, introduced a noticeable power loss, and now this with the fuel.
« Last Edit: June 17, 2018, 03:21:20 AM by Harryc » Logged
Roidfingers
Tuscaloosa, Alabama
« Reply #6 on: June 17, 2018, 08:20:34 AM »
Maybe adjust your air / mixture screw out some, to lean it out.
Harryc
Sebastian, Fl
« Reply #7 on: June 17, 2018, 10:54:52 AM »
Thanks guys, problem solved. Anyone looking for new-ish Cobra pipes in excellent condition. Smiley As a side note, now that I can actually hear the engine, I need to do a valve adjustment. Lol
« Last Edit: June 17, 2018, 11:25:18 AM by Harryc » Logged
« Reply #8 on: June 17, 2018, 06:40:30 PM »
Was asking at how many miles on the tank before the need to pass to let others know you needed fuel.
Harryc
Sebastian, Fl
« Reply #9 on: June 18, 2018, 03:58:37 AM »
I am looking for gas at 140 miles. I can go over 150 on a tank though. I have noticed better gas mileage on non-ethanol fuel as well.
« Reply #10 on: June 18, 2018, 04:13:19 AM »
I would say it was pretty normal then my '97 will go about 130 before reserve.
Harryc
Sebastian, Fl
« Reply #11 on: June 18, 2018, 06:19:13 AM »
@Bighead...thanks!
