February 14, 2026, 10:25:08 AM
Front brake caliper hitting after tire change
Topic: Front brake caliper hitting after tire change (Read 1393 times)
Funbaldguy
grand blanc Mi
June 19, 2018, 08:00:47 AM »
Like it says. I just put wheel back on after tire change. Now the bolt that holds the caliper in place is catching on disk? This is on the speedometer side. If I use a washer with the bolt it doesn’t hit anymore but my brake pads rub? Why is the bolt to long all of a sudden? There didn’t seem to be any washers to lose track of. I have had the wheel off before. Not a issue then? Nothing bad before tire change except the tire. Any help. I don’t want to not go on planned trip for Thursday through Sunday.
Dusty
Mill Bay B.C.
Re: Front brake caliper hitting after tire change
June 19, 2018, 08:36:35 AM »
Did you compress the forks a couple of times before tightening the pinch bolts ? I know from experience that stuff will hit if this is not done.
Search for front wheel installation.
Dusty
Earl43P
Farmington, PA
June 19, 2018, 08:42:18 AM »
http://www.valkyrieriders.com/ShopTalk/ValkMaintManAcrobatPDF.pdf
Download that and go to Page 18.
Follow that procedure exactly and it'll get your axle installed properly to fix the problem.
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
Funbaldguy
grand blanc Mi
June 19, 2018, 09:23:18 AM »
Like others have said. Thanks to this site. Without it I might be lost. Thanks for the help. Was just the fix I was looking for.
Harryc
Sebastian, Fl
June 19, 2018, 12:09:13 PM »
@Funbaldguy, agree the site is cool, but the first week I had my bike I got a Honda Maintenance manual off of EBay. I've never regretted that purchase. There is also a downloadable version, FWIW.
http://www.valkyrienorway.com/download.html
Last Edit: June 19, 2018, 12:12:19 PM by Harryc
http://s724.photobucket.com/user/Harryc56/slideshow/Valkyrie
indybobm
Franklin, Indiana VRCC # 5258
June 19, 2018, 04:19:59 PM »
I think the easiest way to correct this is to loosen the lower pinch bolts on tbe left fork. Apply the front brakes and bounce tbe front a few times. Then tighten the lower left pinch bolts.
So many roads, so little time
VRCC # 5258
Dr K
Southern michigan
Reply #6 on:
June 21, 2018, 04:46:42 PM »
When converting my IS into my wife's trike this winter I found that the front caliper bolts were not the same length some were a little bit shorter when in the wrong place they hit the rotor
Reply #7 on:
June 21, 2018, 05:03:44 PM »
According to the parts breakdown shows that both caliper bolts are the same on the front calipers.
Reply #8 on:
June 21, 2018, 06:05:22 PM »
Quote from: Bighead on June 21, 2018, 05:03:44 PM
i saw that and was kinda surprised cause I too thought they were different.
I'll be changing my brake pads tomorrow so it will be good to see they are the same and I can wipe out the false memory.
