February 14, 2026, 10:26:07 AM *
Author Topic: Converting back to interstate  (Read 1146 times)
northernvalk
Sudbury, Ontario, Canada
« on: June 26, 2018, 06:05:20 AM »
Gentlemen,
The p/o converted my valk to a supervalk, complete with tourer side rails. I need to convert her back for a vacation ride with the mrs. I have already removed the seat and bags, is there anything I should know before taking the top shock mounts off? the bike is on the side stand now, will I need to raise it to full height now or do you think I can compress the shocks without lowering the tire? If I do one side at a time will I be able to do this without a lift? Thanks for the info!
Ramie
2001 I/S St. Michael MN
« Reply #1 on: June 26, 2018, 06:43:02 AM »
I never tried removing the shocks without using a lift.  I would think if you did one side at a time it might work.
9Ball
« Reply #2 on: June 26, 2018, 09:32:29 AM »
I’ve done it on the side stand...not the best way but can be done.
Do one side at a time.  It helps to have a second person.  You can put the lower shock mount on, then lift the rear of the bike by the frame (not the fender!) and slide the top mount on.  It also helps to lube the rubber inserts with silicone grease or equivalent.
The second person should steady the bike so it doesn’t push over when installing the shocks.
Good luck...this is my experience only and I don’t endorse or guarantee anything...do at your own risk.  It’s really not difficult to do.  I installed my Progressive 440s by myself on the side stand.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
northernvalk
« Reply #3 on: June 26, 2018, 10:15:30 AM »
Thanks Guys,
There is a lot more work involved with the full "conversion" vs leaving the stock side rails on, but the tourer rails look so nice!!! We will see how long it stays in dresser mode.... Undecided
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #4 on: June 26, 2018, 07:17:11 PM »
Be careful when removing the two bolts that hold the rails on...  With both removed, it is a b!T@h to line everything back up, when putting the Interstate rails back on  tickedoff
Black Dog
Don't you know...
« Reply #5 on: June 26, 2018, 08:02:47 PM »
Black Dog
Not if you jack th bike from center it is no problem....if you do it on the side stand it will be a bitch.
Dusty
Mill Bay B.C.
« Reply #6 on: June 26, 2018, 09:33:04 PM »
Use a file or grinder to grind a taper on the threaded end of the bolt that bolts through the  rails. Now when you try to align all the parts you just apply a pushing force as you turn the bolt . The taper will help to align everything as you tighten the bolt. Works like a charm   cooldude cooldude
Dusty
northernvalk
« Reply #7 on: June 28, 2018, 10:19:00 AM »
Thanks to everyone for the info.  I will run some stabilizer ropes to the ceiling and use the floor jack and 2x10 to lift the bike up!
