February 14, 2026, 10:25:32 AM
Dunlop D404F 16,000 miles
Topic: Dunlop D404F 16,000 miles (Read 1022 times)
vanagon40
Greenwood, IN
June 27, 2018, 05:48:10 AM »
I got 16,000 miles out of my 150/80-17 Dunlop D404 Front tire. Mostly flat, straight roads in central and northern Indiana. A lot of interstate miles.
Replaced it with the 404 rear tire: 130/90-17 (68H) Dunlop D404R.
Original D404 Front | Worn out D404 Front | New D404 Rear
Last Edit: June 27, 2018, 05:55:53 AM by vanagon40
0leman
Klamath Falls, Or
Re: Dunlop D404F 16,000 miles
June 27, 2018, 06:42:04 AM »
16K is a lot of miles.
I have run the D404F for last 3 front tire changes. I can only get 12-13K out of them. But then we have chip-coat roads around here that eat up tires.
Had to tell which way the tread goes from the pic. did you mount it reversed?
1999 Valkryie I/S Green/Silver
vanagon40
Greenwood, IN
June 27, 2018, 09:45:50 AM »
I did not mount the 150/80-17 Dunlop D404 Front tire reversed. I did mount the 130/90-17 (68H) Dunlop D404 rear tire reversed (on the front rim).
June 30, 2018, 05:29:24 AM »
running same tire on front. 4k miles, tread wore 1/32", new 9/32". Should translate to 30k to wear bars similar to what others have reported. Last front in same size was a Conti-go V-rated which was good for 27k, they don't sell the H-rated tire in the states last I checked.
