April 30, 2026, 08:34:39 AM *
Author Topic: Ignition wire question  (Read 3234 times)
suthrncop
mobile, AL
« on: June 29, 2018, 10:11:31 PM »
Although I used to be mechanically inclined, over the years I have lost most of what I didn't already know.  So here I am today hooking up a small amp and speakers to my 2014 Valk.  I am placing the amp under the seat with a relay and need to tie it into the ignition so I won't run the battery down....SO my question is, where would  the best/easiest place be to tie into the ignition and what will the wire look like?
Thanks in advance for any help
Bill Havins
A roadster!
Abilene, Texas
« Reply #1 on: June 30, 2018, 09:03:38 AM »
Under the seat, very close to where you are installing your audio unit, you'll find two relays, one for the high beam, and one for power to the turn signals/accessories (I think I have that right - doing this from memory).
Anyway, near the two relays you'll find a capped 2-pin plug (Honda refers to the plug as a "dummy" since it is capped and not in use).  The green wire attached to the plug goes to ground.  The Blue/Green wire gets power from fuse #2 which is the "accessories" fuse.  So, this plug is the "perfect" power source for what you're doing.  I have my Rostra Cruise Control plugged into that plug on my Valkyrie.
Hope this helps.
Bill
suthrncop
mobile, AL
« Reply #2 on: June 30, 2018, 11:55:22 AM »
Thanks that is just what I need
suthrncop
mobile, AL
« Reply #3 on: June 30, 2018, 01:59:13 PM »
Found the plug (I think) but it is a green wire and a green/black wire.  Took the cap off of the plug now to try and find the piece that will replace the cap to connect the wires.  I hope it is a common plug that an auto place may carry.  Or is there any way to use the original cap, does it have the necessary internals to attach the wires
« Reply #4 on: June 30, 2018, 06:13:49 PM »
You are better off making your own connections since it will be a bit hard to find the proper connector. Wire colors are correct, but you can verify by removing the #2 fuse and if the power goes off you know you have the correct one also.
« Last Edit: June 30, 2018, 06:21:39 PM by Robert » Logged
suthrncop
mobile, AL
« Reply #5 on: June 30, 2018, 07:48:47 PM »
Yeah, I see that , went to a few box auto parts stores with no luck
suthrncop
mobile, AL
« Reply #6 on: July 02, 2018, 11:22:58 AM »
Checked with the dealership, they said that the outlet is a diagnostic port but there is an adapter to use it as an acc connection.  The piece is $12.  Not sure if it’s the right part though till I can get by there Thursday and look at it
