February 14, 2026, 04:16:18 PM
Air/fuel mixture screw
Topic: Air/fuel mixture screw (Read 2874 times)
buckfever
Michigan
August 16, 2018, 01:19:05 PM »
Can someone tell me where air/fuel mixture screw is on my 98 Valk. Does it require taking the gas tank off? Or is it accessible on the outside of bike?
WintrSol
Florissant, MO
Re: Air/fuel mixture screw
August 16, 2018, 03:09:14 PM »
It is on the bottom, on the intake side, inside a cast tube. See #6 in this drawing:
https://www.partzilla.com/catalog/honda/motorcycle/1998/gl1500ct-a-valkyrie-tourer/carburetor-components
It shows up in two places on that drawing, and the one on the right shows it better.
Last Edit: August 16, 2018, 03:10:45 PM by WintrSol
buckfever
Michigan
August 16, 2018, 03:57:34 PM »
So... not easily accessed. Was hoping i didnt have to take carb assembly off to adjust. Thanx for the info
Leathel
New Zealand
August 16, 2018, 04:01:09 PM »
there is room to do it, more room if you drop the manifold pipes
you also need a D tool for them (Unless sold outside of USA then its phillips)
WintrSol
Florissant, MO
August 16, 2018, 05:51:52 PM »
Kind of pricey, but you can adjust them while the engine is running with this:
https://www.ebay.com/itm/Motion-Pro-90-Degree-1-4-Hex-Driver-Carb-Tool-With-Bits-Honda-Kawasaki/192229367805?epid=1237792539&hash=item2cc1c35ffd:g:LfcAAOSw~rpZUVMS:sc:USPSPriority
!63031!US!-1
Valkyrie0002
Fredericksburg, Va
August 17, 2018, 05:50:16 AM »
Easy to adjust and yes there is more room if you remove the intake tube. Tool is cheap. I got the Heavy Duty one and glad I did because I had a couple tough screws. Also I'd recommend you take a file and round off the sharp edges and corners on the brass end of the tool.
https://www.ebay.com/itm/Hella-Stubby-Tool-for-Pilot-Screws-Valkyrie-GL1500C-GL1500CD-GL1500CT-GL1500CF/331878433060?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Been riding since about 1985. 1st bike was a CB900F then 88 CBR1000 , 1990 VFR750F and 94 CBR1000F. I bought my 2000 Std. Valkyrie new in 01. Was an MSF Rider Coach for 12 years. New owner of a 2014 Valk, Red, Non ABS.
Paladin528
Reply #6 on:
September 06, 2018, 06:46:48 AM »
I cut a slot in all of my pilot screws to make adjustment easier with the bike running. Makes life far easier.
Reply #7 on:
September 06, 2018, 07:42:43 AM »
this is the best honda tool to get, it was org listed for the cbr900.
it has a flexible spring head. been using it for yrs.
07MMA-MT3010B WRENCH PILOT SCREW
http://www.saber-cycle.com/store/product1056.html#1056
can be found for less $$
cef2lion
Central PA
Reply #8 on:
September 06, 2018, 12:20:21 PM »
In the service manual they list the pilot tool as:
07KMA-MN90101 Superseded by
07KMA-MN9A100
Its a Honda 90 degree tool and very pricy.
