February 14, 2026, 04:16:04 PM *
Author Topic: Another petcock issue  (Read 1187 times)
retirednavy
« on: August 24, 2018, 10:42:13 AM »
Im sure this has been asked a million times but I have a new to me Interstate and love it but have been going over it. I removed the stock petcock and rebuilt it after I hooked up the chrome knob gas leaks from the petcock by the shaft. did not leak there before! Do I need to order a new petcock? I would like to stay with what on the bike. Thanks
« Reply #1 on: August 24, 2018, 10:46:19 AM »
The OEM petcock was a pos and gave problems if you want to stay with the OEM rebuild it.
« Reply #2 on: August 24, 2018, 12:14:34 PM »
If you rebuilt it with an OEM "cover set" (169530-me5-025) and
it's not doing right, then you either messed up the rebuild (easy to
do) or need a new petcock (about $125 for OEM)...
Dirty Dave
Montreal, Canada
« Reply #3 on: August 25, 2018, 08:52:26 AM »
I prefer a manual Pingel petcock. No more hydolock worries. Looks sexy too and you get rid of that big plastic chrome plated thingie. Real easy to reach under the tank while riding. I turn it off as I drift into my garage.
Just sayin'
It's weird being the same age as old people
« Reply #4 on: August 26, 2018, 07:30:47 AM »
I don't find it easy to turn the knob on the Pingel but I'm old and ham-fisted I suppose.  I'm saying that comment is gonna vary with the user. I'd love to have the ease of the OEM knob with the reliability of the Pingel but that would take lots of mod work to do. The shafts are in different directions from the inlet & outlet.  I added an extension onto the Pingel lever on both of my bikes that have one. Even so, hard to find even with gloves off. Doesn't help I have somewhat reduced tactile sense in my hands from days gone by.
« Reply #5 on: August 26, 2018, 09:20:49 AM »
Other Honda petcocks. I've a manual one off of a VT1100T, and will try it out whenever I finally take the tank off my IS to do all the work I wish I had the space/time to do it. The reserve stack is defiantly a different length than the Valk's.
Dusty
Mill Bay B.C.
« Reply #6 on: August 26, 2018, 03:45:21 PM »
To the original question , did you remove the petcock from the tank. if you did you have to line it up to point in the right direction to line up with the chrome piece.  On my display model (cut apart to show how it works) the shaft that sticks out of the petcock has 2 flat O-rings with a raised up piece on each edge of the flats. So there are four seals that the gas has to get past to leak out. I would guess that your shaft and chrome piece are not in line with each other causing the o- rings to loose contact on  the inside of the bore or the o-ring in the tank is leaking and the gas ends up on the shaft or the nut is not tight enough  or there is dirt on the sealing surface. Let us know if you can give us more information
Dusty
retirednavy
« Reply #7 on: August 26, 2018, 06:16:05 PM »
Dusty
Sounds like you got it right. I got a new oem on the way and I will line it up good. Thanks
retirednavy
« Reply #8 on: August 27, 2018, 07:00:47 PM »
Dusty was right new EOM works like a charm. If it binds it will leak. Thanks!!
