January 30, 2026, 02:05:37 AM *
Author Topic: Upper Shock bushing thought!!  (Read 2249 times)
roboto65
Conroe,TX
« on: November 12, 2009, 07:22:54 AM »
I was wondering since reading some recent posts about the upper bushings on our Valks. The VTX had come out with a bearing on the upper eye and well I was wondering since the shock takes the shock so to speak LOL what would be the possibilty and I know everything is persay possible with money.
But why could you not machine out the top eye in the shock and fit a bearing for the upper end and grease it everyonce and while and have it last this only pertains to the top since the bottom is not a problem. Pros and Cons from the experts so to speak let me know why not..
I am for sure going to reseach this a little more and let you know what I find..
Here is a link to the VTX shock with bearing part number 12
http://fiche.ronayers.com/Index.cfm/Module/Main/TypeID/26/Type/Motorcycle/MakeID/1/Make/Honda/YearID/47/Year/2006/ModelID/5250/Model/VTX1800C1/GroupID/195243/Group/REAR_SHOCK_ABSORBER_(2)
« Last Edit: November 12, 2009, 07:25:24 AM by roboto65 » Logged
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
PAVALKER
Pittsburgh, Pa
« Reply #1 on: November 12, 2009, 08:40:02 AM »
Actually the lower shock bushing on that shock is a newer nylon (sorta green in color) and will work on the upper and lower Valk (or VTX) shocks that use the rubber.  This is a newer harder neoprene or nylon type material..... I replaced my Valk bushings and a set of worn out Gary's bushings with those, and works well so far.   Very inexpensive compared to the original black rubber ones....
Honda new green bushing no. 52489-HN0-671  (will fit VTX and Valkyrie).  Much better than old stock rubber.
Here is an interesting read regarding shock bushings on the VTX message boards......
http://www.vtxoa.com/forums/showthread.php?t=242281&highlight=shock+bushing
« Last Edit: November 12, 2009, 08:43:45 AM by PAVALKER » Logged
John
