February 14, 2026, 06:05:51 PM *
Author Topic: a couple of questions...  (Read 1207 times)
larswlvs
my littlest riding partner
Akron,Ohio
« on: September 07, 2018, 02:23:49 PM »
I bought the smart switch but did not undo the relays that i had in place. does that make a difference? Should I remove the relays an if i did would my wiring still be protected.  Next question is...has anyone tried the H4 LED bulb as a replacement and how did that work out?
If guns kill people where are mine hiding the bodies
Harryc
Sebastian, Fl
« Reply #1 on: September 07, 2018, 03:24:00 PM »
Don't need a relay for a Smartswitch. It wires directly to your battery.
« Reply #2 on: September 07, 2018, 03:38:14 PM »
I thought the SmartSwitch came with its own relay ?
« Reply #3 on: September 07, 2018, 08:25:57 PM »
Yes Mr. Head; the smart switch has it's own relay inline. If an LED bulb is used, then the smart switch isn't needed. The low current draw of the LED reduces the current on the start button.
larswlvs
Akron,Ohio
« Reply #4 on: September 08, 2018, 01:34:57 PM »
so i can remove all my relays .. for example running lights, head lights and air horn?
« Reply #5 on: September 08, 2018, 02:37:53 PM »
No. The SmartSwitch only controls the headlight. Leave your running light relay and horn relay. The purpose of the SmartSwitch is to provide more amperage to your headlight while reducing the amperage that has to go thru your starter button.
larswlvs
Akron,Ohio
« Reply #6 on: September 08, 2018, 08:53:55 PM »
OK, thanks a lot , ill remove the headlight relay and running light relay since they are now LEDS
Gideon
Indianapolis, IN.
« Reply #7 on: September 12, 2018, 10:21:28 AM »
May I ask, what LED Bulb did you use in your headlight?
