Savago
« on: September 11, 2018, 09:38:38 AM » |
Dear friends
I noticed this week that my I/S@99 (with 82K miles) is making a clinking noise while riding around 25 to 30mph.
It is not loud but it is definitely there. It will happen either with clutch engaged or disengaged as also on neutral with the bike moving.
Any usual suspects? I thought maybe u-joint or maybe wheel bearings? I pray to Jesus that is not the final drive again...
I have the impression that the noise coming from the rear wheel area...
Further info: a) It has a new OEM alternator (Hitachi made in Japan) b) I'm running Rotella T4 oil on it. c) Final drive has Mobil 1 synthetic oil. d) Final drive was replaced last year (and lubed with Honda Moly).
Best regards
Savago
Tfrank59
'98 Tourer
Western Washington
« Reply #1 on: September 11, 2018, 09:45:44 AM » |
I imagine you've checked that it's not just a rock or nail in the tire? I've had that happen more than I'd like to admit.
-Tom
Keep the rubber side down. USMC '78-'84 '98 Valkyrie, ‘02 VTX 1800, '96 Royal Star, '06 Drifter, '09 Bonneville, '10 KTM 530, '04 XR 650, '76 Bultaco, '81 CR 450, '78 GS 750...
« Reply #2 on: September 11, 2018, 10:18:43 AM » |
Can you jack it up and spin the tire in neutral ? I wouldn't think ujoint or rear differential. Wheel bearings maybe. Most likely a rock or something like tfrank said.
« Reply #3 on: September 11, 2018, 10:28:46 AM » |
Brakes are notorious for weird noises. Esp those spring steel clips on ours.
On the other hand, I spent several days chasing down a noise that turned out to be a small rock in the tire tread. But it didn't clink, it ticked.
« Last Edit: September 11, 2018, 11:28:24 AM by Jess from VA »
Savago
« Reply #4 on: September 11, 2018, 10:59:50 AM » |
All good feedback.
I will put the bike in a jack and see if there is anything stuck in the rear tire.
Concerning the brakes: pressing the foot pedal to engage the rear brake won't change the clinking sound.
« Last Edit: September 11, 2018, 11:08:17 AM by Savago »
SirLancelot
« Reply #5 on: September 11, 2018, 11:22:45 AM » |
Does the rhythm of the clink change with road speed?
« Reply #6 on: September 11, 2018, 11:38:12 AM » |
All good feedback.
Try the front brakes. ***
Dusty
« Reply #7 on: September 11, 2018, 12:38:10 PM » |
All good feedback.
Try the front brakes. *** I'll second this suggestion . Mine was front pads rattling around. I bit of front brake pressure while riding made it go away. Dusty
Savago
« Reply #8 on: September 11, 2018, 01:23:05 PM » |
Yep, it does. It starts around 20mph and goes away past 30mph.
Tfrank59
'98 Tourer
Western Washington
« Reply #9 on: September 11, 2018, 05:18:33 PM » |
Does it go away at 30 or just become inaudible? If the noise actually stops at a certain speed, it might indeed be wheel bearings. You might not be able to fully diagnose in that case without disassembly, though with the wheel(s) off the ground you should detect something--some wheel slop, feels rough on rotation, something just not right If you can rule out not something stuck in the tire, brakes not being the cause, and the wheel bearings seem okay, then it's time to look at the final drive, which is of course NOT what you want to hear but it would be the likely culprit and would require full disassembly  (NOTE: if the clicking corresponds to wheel rotation (1:1), then it wouldn't perhaps be the drive shaft, as its rotation is many times more frequent than the wheel's)
« Last Edit: September 11, 2018, 06:36:30 PM by Tfrank59 »
-Tom
greggh
« Reply #10 on: September 11, 2018, 05:55:05 PM » |
I had a similar problem Was making a Tin like noise at low speeds and moderately low speeds. The culprit was a a header pipe weld had broke where the headers pipe feeds into the exhaust canister. Just my 2 cents
Valker
Wahoo!!!!
Texas Panhandle
« Reply #11 on: September 11, 2018, 06:36:20 PM » |
Is it like this one? https://www.youtube.com/watch?v=wn7gJc4QasMThis was something broken loose in my exhaust pipes. I had them glass packed to stop it.
« Reply #12 on: September 12, 2018, 02:15:30 AM » |
Riding down the road, when you pull in the clutch, does the sound change? If not, when you apply the brakes, with the clutch lever in, does it change? If not, when you release clutch lever, does it change? If not, when you gas it full, does it change? If not, I'd look at wheel bearings next, by elevating either both or one wheel at a time, to inspect movement. I think, even if it's in the drive train, when you apply full power, the noise would change some. But, maybe not.  Good luck.
greggh
« Reply #13 on: September 12, 2018, 03:13:26 AM » |
No mine was not that loud or that constant The head pipe weld was broken
« Reply #14 on: September 12, 2018, 06:27:48 AM » |
Dear friends
Best regards
Savago
My guess is left rear wheel bearing. when you get the back end up in the air grab the rear wheel at the bottom and try to move it side to side. Any movement will be minuscule (more like a tic sound) but its the tell tale sign of a bad wheel bearing.
Tfrank59
'98 Tourer
Western Washington
« Reply #16 on: September 12, 2018, 02:12:27 PM » |
I just went down to Harbor Freight and bought the one that's rated for 1500 pounds. I think it was a hundred bucks. I've been using that for about 4 years for both of my motorcycles and it works great. But for my Valkyrie I had to build the adapter that's in the shop talk page where all the dimensions and everything are provided
-Tom
« Reply #17 on: September 12, 2018, 04:26:34 PM » |
That lift you ordered isn't going to be stable. It's meant for a tablelift where the front wheel is clamped down. You need to cancel that order and get a motorcycle jack.
Savago
« Reply #18 on: September 12, 2018, 04:34:21 PM » |
@Sandy: Good point!  I have the bike in a wheel chock with jacks in the engine crash bars, do you think that wouldn't hold the bike in place while using the lift? A few photos: https://photos.app.goo.gl/UKBbd6Jsc7D6Mumb8
« Reply #19 on: September 12, 2018, 04:49:30 PM » |
@Sandy: Good point!  I have the bike in a wheel chock with jacks in the engine crash bars, do you think that wouldn't hold the bike in place while using the lift? A few photos: https://photos.app.goo.gl/UKBbd6Jsc7D6Mumb8Savago, looking at your pics, it probably will work with chock setup. But, I'm with Sandy. Cancel your order and get the proper Jack. You can get them at Sears or Harborfreight for $89, sometimes on sale for less. It will be more stable, and you will be able to lift the whole bike. Working on the front end if you need to in the future.
kodiakfisher
« Reply #21 on: September 13, 2018, 08:28:00 AM » |
I will offer up a few suggestions as I have chased them both and keep in mind my hearing isn't the best anymore.
First culprit would be to tighten the exhaust header nuts ONLY 7ft lbs of torque or just barely snug. They come loose and at lower speeds you can hear the exhaust tink/ping out.
The other thing that happens as fall approaches and humidity in the air increases is condensation inside our exhausts and this also provides a nice tink/ping sound as the bike warms up and the steam goes out one of the holes on the bottom of the exhaust about where the passenger foot pegs are.
Kodiakfisher
