February 14, 2026, 06:01:04 PM *
Author Topic: Well, Carbs Are Gummed Up Good Now....  (Read 2062 times)
Steve K (IA)
Cedar Rapids, Iowa
« on: September 11, 2018, 12:34:09 PM »
So...went through a divorce this past winter.  She took Everything!  Been going through what I imagine has been depression.  Lost all interest in riding...or anything else.  Sold my Std and I've only had my I/S out twice this summer for about 25 miles each time.  Got the I/S out the other day and it will hardly run at slow speed as you can imagine.  Had about 10 oz of Sea Foam and put into about 5 gallons of gas that was in the tank.  Over 2 days I've taken it out for a 10 mile ride each day slowly riding around back streets trying to get the Sea Foam to work through the slow jets.  So far it's not working.  The bike runs fine at higher RPM's.
I know Berryman's is more aggressive.  What are the thoughts of possibly adding this to the tank while I still have Sea Foam in there?  Or should I go with a stronger solution of Sea Foam.
States I Have Ridden In
Dusty
Mill Bay B.C.
« Reply #1 on: September 11, 2018, 12:49:25 PM »
Steve
 I'd  ride it some more. 2 days is not a lot of time. If it was my bike I would ride where it doesn't stumble then  get  some premium Chevron and more seafoam in it once I run the gas that's in the tank out. I wouldn't expect to see results until a couple of tanks full of fuel are burned up. Better days are ahead.     cooldude
Dusty
« Reply #2 on: September 11, 2018, 01:00:20 PM »
I've mixed my additives many times with no ill affects.
I'm not saying it will work for you, but it shouldn't hurt.
Maybe you should have dumped the tank first (esp corn gas).
(Sorry for your troubles Steve.  I have that particular T shirt.)
« Last Edit: September 11, 2018, 01:02:11 PM by Jess from VA » Logged
Valkyrie0002
Fredericksburg, Va
« Reply #3 on: September 11, 2018, 01:29:29 PM »
I used a lot stronger mix in mine, B-12 at first and now Techron.  It took about 50 miles to really notice a difference.
I would have dumped the old gas and started with a couple fresh gallons and additive.
Been riding since about 1985.  1st bike was a CB900F then 88 CBR1000 , 1990 VFR750F and 94 CBR1000F.  I bought my 2000 Std. Valkyrie new in 01.  Was an MSF Rider Coach for 12 years.  New owner of a 2014 Valk, Red, Non ABS.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #4 on: September 11, 2018, 01:58:11 PM »
I bought this bike new in 2000 and it has had nothing but ethanol in it 99% of it's life with no problems except now.  And I can't blame the gas, it's because I let it set.  It has ethanol free gas in it at this time.  Put it in last winter, and also a bit this spring to top it off.  I did this two winters ago when storing and noticed it started a little easier at first start up in the spring.
bill-jr
VRCC # 35094
murfreesboro
« Reply #5 on: September 11, 2018, 02:17:10 PM »
She didnt take EVERYTHING you still got the bike and your balls . . .
Start using both of them more this year . .
99' Black tourer
« Reply #6 on: September 11, 2018, 03:34:37 PM »
Amen 2funny 2funny
Valker
Wahoo!!!!
Texas Panhandle
« Reply #7 on: September 11, 2018, 04:58:12 PM »
My last Valk purchase ran about like yours sounds to be. It took several different brands (Berryman's seemed to help the most) a bit over 1000 miles before mine ran right.
Lyle Laun
Calgary, Ab
« Reply #8 on: September 11, 2018, 05:21:24 PM »
I've never been shy to mix Techron with B12 and load them very heavy (think a couple of cans in a half tank of fuel). Never had any luck with Seafoam.
Regards
Lyle
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
Leathel
New Zealand
« Reply #9 on: September 11, 2018, 05:24:13 PM »
if its old fuel in there I would be ditching that and starting with fresh fuel..then a strong brew and clock up some miles
SPOFF
Derry, NH
« Reply #10 on: September 11, 2018, 05:40:14 PM »
I suspect the Feds pulled a fast one on the formula of their corn-crap gasoline. For 21 years my Valk laughed at ethanol, but no more. So far this year I've rebuilt 10 clogged carburators and I still have the snowblower to go...
Hopefully a chemical mix will clean out your pilot jets. I just finished a carb removal and complete rebuild. It took months. Next time I will simply remove the chrome intakes, drop the carb bowls in place, and screw in 6 new pilot jets.
Savago
Brentwood - CA
« Reply #11 on: September 11, 2018, 06:16:47 PM »
All good advice.
After the carbs are running fine, Stabil Marine is your friend to treat the gas.
Mine I/S seat for 1 year and the carbs were not gummed up because I treated the gas with Stabil.
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
« Reply #12 on: September 11, 2018, 08:55:11 PM »
I run B-12 every once in awhile...bout 1/2 can to a tank...but then again, I start her up every day...I ride her every day and on the stormy days, just start her up and get her warmed up for about 10 min. and turn her off...This seems to be good for my Girl...Oh, by the way, there is life after divorce...heck, its a good way to lose weight...on the average about 12 lbs...Ride safe...!!!
mrgeoff/SANDMAN
Steve K (IA)
Cedar Rapids, Iowa
« Reply #13 on: September 11, 2018, 10:21:09 PM »
Lost 52 lbs since Jan.   Wink
« Reply #14 on: September 12, 2018, 02:01:00 AM »
Hang in there Steve K, it only gets better.  Sounds like both you and your girl (F6 type) just need more wind therapy.
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #15 on: September 12, 2018, 10:26:52 AM »
Hey Bro,
Sorry to hear bout the I/S issues...  Try some StarTron, great stuff  cooldude cooldude  Drain the tank, and get some new 'go juice' in there. Add the StarTron, and point yer butt at my place  Wink  That should be good for multiple tanks, and maybe be enough to clear things up. The WI gang is planning a meet n greet  on Oct 7th in Baraboo...  If you come up on Friday before that, it will give me time to pour a few cocktails in ya, and we can do the 'Woman Haters Club' paperwork while we talk...
Black Dog (gimme a call when you have some time to yak)
Don't you know...
indybobm
Franklin, Indiana VRCC # 5258
« Reply #16 on: September 12, 2018, 11:57:09 AM »
i do not think anything beats Chemtool B12 for problems like this.
« Last Edit: September 17, 2018, 01:01:48 PM by indybobm » Logged
So many roads, so little time
VRCC # 5258
Steve K (IA)
Cedar Rapids, Iowa
« Reply #17 on: September 12, 2018, 05:16:44 PM »
Hey Bro,
Hi Buddy,
Yes, the gas was fresh.  Tonight after a total of 47 miles over 3-4 days riding around a nearby industrial area in 2nd gear at under 1500 rpm's it finally cleared up.  Probably had at least 1 1/2 cans of Sea Foam in there...not real sure, kept adding it 5 oz at a time to 3 gal of fresh gas I had in it.  Anyway, it's back to the way it's suppose to be.  cooldude
I'll give you a call.
JimC
SE Wisconsin
« Reply #18 on: September 12, 2018, 07:41:05 PM »
Steve,
I really can't say much about the above club, but I agree with Black Dog, swing east, the weather is supposed to be very nice the next couple weeks. You are lucky for a couple reasons, your bike is now running good, and you no longer have a wife to tell you NO.
Jim
Jim Callaghan    SE Wisconsin
Paladin528
« Reply #19 on: September 13, 2018, 04:51:43 AM »
If you need them cleaned really good get a can of this:
Drain the carb bowls and turn the petcock off.
Disconnect the fuel line from the tank and make an adapter hose that will fit over the nozzle of the can and step up to fit snug inside the fuel line.
Fill the carbs with the cleaner.  It foams up so you have to spray some then wait then spray some more.
Eventually it will come out of the carb vents.  Stop at this point because this stuff will remove the paint from your engine fairly quickly.
now let it sit for about 24 hours....
after waiting drain the carb bowls again.
now the really fun part.  Try to start the bike.  it will NOT want to run initially and when it finally does it will run like absolute crap.  it will smoke and puke and stink.  This will go on for about 20 minutes and eventually smooth out.
At this point your carbs should be absolutely spotless and shiny on the inside.  The slow jets should be ungunked good.
If this doesnt work you will need to pull the carbs and clean them mechanically
9Ball
« Reply #20 on: September 13, 2018, 06:33:27 AM »
I can’t see the image you attached...not sure if it’s me or everybody.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #21 on: September 13, 2018, 08:33:12 AM »
It’s not you.
Forge
San Antonio, TX
« Reply #22 on: September 13, 2018, 06:40:57 PM »
Your pic isn’t coming up. What is the product called?
hueco
WACO,TEXAS
« Reply #23 on: September 16, 2018, 08:13:21 PM »
Pull the carbs. Thoroughly clean.  Replace the slow speed jets with new. Do a desmog. All problems past and present solved. With the Valk any way.
« Last Edit: September 16, 2018, 08:16:33 PM by hueco » Logged
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« Reply #24 on: September 17, 2018, 02:55:17 AM »
The drama has built up sufficiently...what it the product called?
« Reply #25 on: September 17, 2018, 05:46:55 AM »
It's probably just seafoam.  There's lots of videos of doing this on cars and all the white smoke
Doug1952
Carol Stream, IL
« Reply #26 on: September 17, 2018, 06:59:02 AM »
Steve - I had a similar personal experience last fall.  After the dust settled, I decided to do something for myself - took my beloved blue standard to The Attic Rat for his performance work.   Amazing results that will bring out the stupid in you if you aren't careful!   Money well spent and better than talking to some therapist half your age whose only response is "well...what do you think?"   Take care.
indybobm
« Reply #27 on: September 17, 2018, 01:07:10 PM »
This is what Paladin528 was trying to post.
It is a Suzuki product called - CARB & COMBUSTION CHAMBER CLEANER 385G
https://www.suzuki.ca/en/carb-combustion-chamber-cleaner-385g-aerosol-can-500
VRCC # 5258
« Reply #28 on: September 17, 2018, 01:15:03 PM »
It’s not you.
  Grin
Edvalk
Dayton Ohio
« Reply #29 on: September 18, 2018, 03:13:04 AM »
I run a 1/2 can of Berryman's b12 to 1/2 tank of gas  every 2 months  through out the riding season. If it sits for more than a couple weeks I'll fill the tank and put a lite dose of marine stable .We have non ethanol premium locally now and I will use it for winter storage plus stable .
1998 valkyrie standard , 2007 Suzuki Bandit 1250
Forge
San Antonio, TX
« Reply #30 on: September 20, 2018, 05:28:04 PM »
So I’m guessing this isn’t available in the US?
