December 15, 2025, 12:04:17 PM *
Author Topic: Rear turn signal relocation  (Read 3206 times)
Hot Rod
East Tennessee
« on: October 16, 2018, 08:21:47 AM »
Need a little help here. Got a set of bags coming to mount on OEM mounts & I'm pretty sure I'm going to have to make a bracket to relocate the rear turns. Looking for suggestions ! Also does the rear fender have to be removed to unplug & detach signals ? Any help will be much appreciated !
https://www.tsukayu.com/QuickDetachableStrong.html
“The bravest are surely those who have the clearest vision of what is before them, glory and danger alike, and yet notwithstanding, go out to meet it.” Thucydides 460 - 455 BC
« Reply #1 on: October 16, 2018, 08:25:18 AM »
Hang in there... there's a regular poster here who has
a great relocation solution,...
bscrive
Ottawa, Ontario
« Reply #2 on: October 17, 2018, 06:43:49 AM »
Here you go Hot rod.  Courtesy of Jerry.
http://www.valkyrieforum.com/bbs/index.php/topic,86046.0.html
Hot Rod
East Tennessee
« Reply #3 on: October 17, 2018, 07:28:19 AM »
Thank you ! I suppose I'll have to remove rear fender to get to plugs ? I may use aluminum instead of steel as it would be a lot easier to work with .......
bscrive
Ottawa, Ontario
« Reply #4 on: October 17, 2018, 02:06:14 PM »
Yes, the fender needs to be removed.  Aluminum gets brittle when it is bent, so the aluminum might break at the bend and the signal lights might fall off after a while.
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #5 on: October 19, 2018, 07:19:09 PM »
  Nice to see I still have a place here,  cooldude Steel is easy, put it in the vise and slowly draw the hack saw back and dig shallow lines where you want the bend. A 32nd is fine. Stick it back in the vice with the short piece up.  Start to bent it in with the cut or score on the inside, using a huge crescent wrench, then Finish it by tapping it over with a mallet. Scoring the Metal always works.
Hot Rod
East Tennessee
« Reply #6 on: October 20, 2018, 05:25:23 AM »
Thanks ! You wouldn't happen to remember the size of that piece would you ? Also Did you just simply bolt it on where the reflector used to be ?
_Sheffjs_
Sarasota FL
« Reply #7 on: October 20, 2018, 10:07:44 AM »
Let me take a look, I might just have that piece around somewhere and I can just post it to you.
_Sheffjs_
Sarasota FL
« Reply #8 on: October 20, 2018, 11:43:21 AM »
Bracket found.  Pm your address and I will send it to you. Once received you will have full understanding of the madness.  A little post money would do to my PayPal. The part is free.
Hot Rod
East Tennessee
« Reply #9 on: October 20, 2018, 04:14:55 PM »
PM Sent ....THANKS !
_Sheffjs_
Sarasota FL
« Reply #10 on: October 22, 2018, 07:06:44 PM »
Will post it out Tuesday.  cooldude
