June 26, 2025, 12:01:40 PM
Quick Question on Timing Belt Replacement
Topic: Quick Question on Timing Belt Replacement (Read 963 times)
jblvalk
Phoenix, AZ
November 13, 2018, 09:23:46 AM »
The manual calls for a Sealant to the one bolt on the timing belt cover. What kind of sealant should be used and just curious, why this one bolt??
Thanks-
Tfrank59
'98 Tourer
Western Washington
Re: Quick Question on Timing Belt Replacement
November 13, 2018, 09:51:33 AM »
others will chime in on this...good catch on this detail. it's because that one tapped hole goes into the motor housing deeper (presumably breaks through into an oil/coolant passage) and can therefore leak without some sealant on its
threads
. I'd go with something like a little high temp permatex--I think that's what I used 3 years ago and it's been fine.
-Tom
Keep the rubber side down. USMC '78-'84
jblvalk
Phoenix, AZ
November 13, 2018, 11:00:40 AM »
Quote from: Tfrank59 on November 13, 2018, 09:51:33 AM
threads
Interesting. Thanks for the info and will have some permatex handy when I get the parts in next week!
November 13, 2018, 12:07:48 PM »
I have my own theory on this because of how my bike behaves. Bottom line I dont use any sealant on that bolt and its never been a problem. I have done 4 or 5 bikes, never sealant never a problem.
November 13, 2018, 02:27:19 PM »
Use a Permatex non hardening sealant made for petroleum distillates. That hole goes into an oil area but it's not a pressurized passage.
=> InZane XXV
