January 30, 2026, 02:06:38 AM *
Author Topic: Petcock rebuild, questions  (Read 4943 times)
Kilroy
Clearwater, Florida / Overland Park, KS
« on: November 16, 2009, 07:15:54 PM »
Hi All,  Did the petcock rebuild using the kit from HDL as well as the new filter screen.  All went well bike seems to run just fine, after it warms up.  My questions are 1. After the rebuild it appears that I have to use the choke to keep it running until it is warm enough to ride, what could be the issue here.  2.  appears that the reserve is somewhat shorter than with the original, rode 151 miles on the tank did not hit reserve and put in 4.6 gals.  Before I would hit reserve at 130 or so.   What are your thoughts on these two differences..  Thnaks
Kilroy
"I was here, but now I'm gone"
MP
North Dakota
« Reply #1 on: November 17, 2009, 05:18:11 AM »
I can't see how the "cover set" rebuild would affect either of those?
MP
"Ridin' with Cycho"
« Reply #2 on: November 17, 2009, 06:16:16 AM »
Sounds like you disturbed the standpipe to the degree where you have lost the reserve function of the petcock. Most likely while changing the screen.
« Reply #3 on: November 17, 2009, 07:14:51 AM »
There's a little tube that you have to jamb up into the new petcock screen, there's a place
for it about halfway... it is a functional part of the reserve scheme... do you remember doing
that part?
Ida know about the choke... did you do one of the vacuum tests after the rebuild to insure
that the petcock is functioning properly (WRT flow/no-flow)?
Pete
« Reply #4 on: November 17, 2009, 12:37:17 PM »
I have seen the petcock standpipe develop a vertical linear crack, that allows enough gas thru for the Valk to run, although sometimes not very well. That could account for the choke issue if the fuel level was below the top of the standpipe and the petcock was turned to on, not reserve. I do not know why or how the crack develops, the crack is hard to see, looks like a fine line 1 to 2 inches long, running up and down, usually about the middle of the pipe. Good luck on finding the issue. Thanks Pete.
Minnie Miles
Florence, Texas
« Reply #5 on: November 20, 2009, 01:44:19 PM »
Question....how do you take the control knob off the petcock
Minnie Miles
Florence, Texas
« Reply #6 on: November 20, 2009, 02:55:39 PM »
Thnx Guys #2 phillips
5_19
Dublin, Texas
« Reply #7 on: November 20, 2009, 05:29:22 PM »
Kilroy
When I rebuild mine I got better milage and the shop didn't smell like fuel anymore. I went from 120 to 140 miles before hitting reserve because it was leaking fuel. It is critical to get the new screen and the reserve tube with the gasket inside installed correctly. Usually I can add 4.2 gallons shortly after it hits reserve regardless of milages. I don't know how working on the petcock would effect your choke.~TJ
IBA # 45723
2009 BMW R1200 GSA
Kilroy
« Reply #8 on: November 20, 2009, 05:52:54 PM »
Thanks everyone,  Lots to think about and look into.  Next time I get the gas down I will take the tank off and inspect the petcock and see what I have now that I have an idea what to look for.
Thanks for all the tips!
Kilroy
Sonny
Holt, Mo.
« Reply #9 on: November 24, 2009, 06:18:38 PM »
Mine is leaking too.  Never heard of HDL who are they?  Tried to find a kit on the net didn't have any luck.
What a great day, lets ride!
1999 Valkyrie Standard
2003 VTX, 1800C
John U.
Southern Delaware
« Reply #10 on: November 24, 2009, 09:18:27 PM »
HDL is Honda direct line: http://www.hdlparts.com/
They have a parts fiche you can order from. The rebuild kit for the petcock is called a Cover Set. You will need to order the screen as well.
Minnie Miles
Florence, Texas
« Reply #11 on: November 26, 2009, 04:32:23 PM »
http://www.directlineparts.com/product.asp?pid=9177&str=2
I just finished putting this 1 on and it was a snap $17.99 + handling
Sonny
Holt, Mo.
« Reply #12 on: November 28, 2009, 06:40:44 AM »
Thanks for the info guys!   I'm not much good at this computer thing. Any and all help is appriciated.
2003 VTX, 1800C
frosty
« Reply #13 on: November 30, 2009, 07:35:42 PM »
Some are putting an elec. shutoff on now to prevent hydrolock. No gas travels unless the key is on.
