December 31, 2025, 09:52:20 PM *
Author Topic: Bad noise was Pics of open starter switch?  (Read 1631 times)
Valker
Wahoo!!!!
Texas Panhandle
« on: November 20, 2018, 02:26:31 PM »
I'm not feeling the greatest, so my memory is not great. Does anyone have a picture of the inside (open) starter switch housing? I can't remember what goes under each of the small brackets. Any help would be appreciated.
« Last Edit: November 20, 2018, 05:25:27 PM by Valker » Logged
« Reply #1 on: November 20, 2018, 04:25:39 PM »
Shoptalk, starter switch repair?
How about a parts fiche?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: November 20, 2018, 04:31:02 PM »
I checked those. Parts fische only shows the assembled switches-guess because they don't sell the parts. I had a brain fart. I have three Valks. I just took one of the other switches apart to find the answer.
Thanks for the help though. I'm blaming it on my heart attack a couple weeks ago. Not thinking straight yet.
« Reply #3 on: November 20, 2018, 05:06:02 PM »
Man I'm sorry to hear that Eric.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: November 20, 2018, 05:23:58 PM »
Switch works, but turning it over it makes this bad noise. Anybody know what it is? I’m not going to fire it until I find out.
https://youtu.be/ma_F7BcnD4Y
JimC
SE Wisconsin
« Reply #5 on: November 20, 2018, 07:19:01 PM »
Just guessing
That sounds like starter?
Starter loose?
Could the starter have bad or missing teeth from a hydro lock at some point?
Jim
Jim Callaghan    SE Wisconsin
RonW
Newport Beach
« Reply #6 on: November 22, 2018, 07:14:17 AM »
this is a photo posted by another member which I annotated. The kill switch wires aren't visible but those wires go underneath the start button wires when they pass under the wire retainer, if that makes any sense.
2000 Valkyrie Tourer
Valker
Wahoo!!!!
Texas Panhandle
« Reply #7 on: November 22, 2018, 07:20:38 AM »
Great. Thanks!!
« Reply #8 on: November 24, 2018, 03:40:53 PM »
Sure sounds like hydrolock to me. Sounds like the starter gears slapping together inside the case. If only 1 is broken it will make enough contact to turn over, if 2 in a row are broken it will just spin without trying to start.
« Reply #9 on: November 24, 2018, 08:28:11 PM »
Usually it's the gear on the motor that break. Turn the engine over a little by rocking the bike in gear, and then try the starter again.
You can also remove the starter and look it over.
« Reply #10 on: November 25, 2018, 04:58:27 AM »
When you remove the starter you will be able to look into the hole you pulled the starter from and see if the bear is broke. 95% of the time it is the small gear just off to the right. Not the one the starter contacts but the next one. Easy to see with starter out.   cooldude
Hooter
S.W. Michigan
« Reply #11 on: November 25, 2018, 05:00:38 AM »
[/quote
Just for the halibut, put the battery on a charger and make sure the battery is up to snuff. Then try it and see if it makes the same noise.
« Reply #12 on: November 25, 2018, 01:41:48 PM »
A post of the starter gear shear.
http://www.valkyrieforum.com/bbs/index.php/topic,70846.0.html
« Reply #13 on: December 07, 2018, 09:16:26 AM »
find the problem?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #14 on: December 07, 2018, 01:26:46 PM »
find the problem?
Fixed the switch housing issue, but haven't got it running yet. I had a couple of heart attacks in November, and those slowed the progress considerably. I hope to get back to work on it soon.
« Reply #15 on: December 07, 2018, 02:43:31 PM »
find the problem?
Yeah, Those heart attacks will definitely slow a feller down.  I hope you're back to normal soon.  Take care.
« Reply #16 on: December 08, 2018, 09:05:14 AM »
find the problem?
Yeah, my dad had one back in August,  he has been slow doing things and following the doctors orders. I think it scared him because he has never listened to anyone before. Take care of yourself, the bike will be there when you are ready.
