August 21, 2025, 09:10:06 PM *
Author Topic: Front wheel  (Read 1382 times)
~ Ron ~
It's the right thing to do
Ahwatukee, Arizona
« on: December 05, 2018, 08:09:03 AM »
I have a 2000 Valkyrie Standard and the front wheel is 18". on the specs it says 17". does anyone else has an 18" front wheel?
~ Ron Pierce ~
~Ahwatukee, Arizona~
~VRCC 20050~
~TOI  27850 ~
~2000 Valkyrie / DFT ~
Daniel Meyer
The State of confusion.
« Reply #1 on: December 05, 2018, 09:12:56 AM »
I'd love to see pics!
But that is not an OEM Valk wheel...
CUAgain,
Daniel Meyer
« Reply #2 on: December 05, 2018, 11:00:38 AM »
18" front wheel, aftermarket wheel, which will greatly fund your retirement when u sell it.
knockdolian
« Reply #3 on: December 16, 2018, 11:07:25 AM »
Will that not upset the speedo ?
bill-jr
VRCC # 35094
murfreesboro
« Reply #4 on: December 16, 2018, 12:22:10 PM »
I think this was a joke thread . . .
No pics it never happened . . .
99' Black tourer
N8171S
Marlboro, Mass
« Reply #5 on: December 16, 2018, 12:52:02 PM »
My valk has a 19 inch front wheel & tire.
« Reply #6 on: December 16, 2018, 04:42:37 PM »
If you look at his avatar, it's been triked. So I figured that the front wheel has been changed to an aftermarket.
Only if the outside diameter of the replacement rubber is larger than the OEM. Or it might just take up the slack for the 5 or was it 10 % that the speedo is out by.
h13man
Indiana NW Central Flatlands
« Reply #7 on: December 17, 2018, 05:30:51 AM »
18" wheel that looks similar to a Valk comes from a Honda Shadow Sabre model.
« Reply #8 on: December 17, 2018, 05:44:27 AM »
Depends on the tire size.  You can put a narrower or lower aspect ratio tire on a larger diameter rim and end up with close to the same overall diameter.  A slightly larger diameter would actually make the speedo more accurate, as with an OEM-sized front wheel/tire, the speedo reads faster than actual speed.
turtle254
Livingston,Texas
« Reply #9 on: December 17, 2018, 06:24:57 AM »
will that front wheel fit a Valkyrie
h13man
« Reply #10 on: December 18, 2018, 06:05:23 AM »
Not w/o a lot of revising as the Sabre has a single disc brake set up.
SCain
Rio Rancho, NM
« Reply #11 on: December 19, 2018, 10:01:32 AM »
I think we are still waiting to see that pic of the 18" wheel.
Steve
Leathel
New Zealand
« Reply #12 on: December 19, 2018, 10:31:51 AM »
might be waiting a while, the OP has 18 posts since 2011 so I figure he doesn't setup post notifications..... or spend a lot of time on here checking Tongue
