January 01, 2026, 12:00:35 AM *
Author Topic: Low Budget Foot Warmers  (Read 1084 times)
pancho
Bonanza Arkansas
« on: December 10, 2018, 08:42:24 AM »
I had these hand grip heaters laying around
https://www.amazon.com/gp/product/B074TFCHG7/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
that I was not going to use for their intended purpose, so I decided to put them to use as heaters for my steel toed riding boots. I had the male and female connectors that are commonly used for heated apparel that will carry at least 10 amps,
https://www.amazon.com/gp/product/B072BXB2Y8/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
put them on the heaters.
and made a harness that would run inside my pants and out the waist. To control the heaters, I used a pulse width modulator, not really a voltage regulator, but supply's the 12 volts for shorter or longer periods of time.
https://www.ebay.com/itm/6V-90V-15A-Pulse-Width-Modulator-PWM-DC-Motor-Speed-Control-Switch-Controller/162836712937?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
This will not work to supply an electronic circuit, but for a resistive load like this it is fine as the RMS voltage will go up or down.
It works fine sitting in the kitchen,, I am going to put the PWM under the seat for now with the control hanging over the right side cover. If it works good enough, I will mount the PWM permanently and put the control in the fairing.
