January 01, 2026, 12:00:33 AM *
Author Topic: broke another bolt update  (Read 1211 times)
matt
Derry New Hampshire
« on: December 11, 2018, 02:22:02 PM »
so its winter time for more powder coating, thinking about doing crash bars so on shifter side rear bolt by shifter with 1/4 drive and snap freeking bolt breaks!!!!!   i gave up right there. so question does any one know does it screws into frame or is there a  nut pressed into frame?  next question i look at parts pic and it shows spacers on outside of crash bar mine are between bar and frame. i have never had this part off so any help would be greatly appreciated oh its a 1998 standard
Matt
well I removed crash bar and bolt had broke right at spacer was able grab it and spin it out, now to try other side
« Last Edit: December 16, 2018, 03:50:36 PM by matt » Logged
LB
2003
Upstate South Carolina
« Reply #1 on: December 11, 2018, 03:54:00 PM »
Spacer goes between the bar and the frame. The threaded section for the bolt  is welded to the back side of the frame. You can see it easy with an inspection mirror.
« Last Edit: December 11, 2018, 03:55:51 PM by LB » Logged
da prez
Wilmot Wi
« Reply #2 on: December 12, 2018, 11:48:01 AM »
  If it is the bolt I am thinking about , the frame section can be removed and the repairs can be done on the work bench.
                                                   da prez
indybobm
Franklin, Indiana VRCC # 5258
« Reply #3 on: December 12, 2018, 12:25:32 PM »
The nut is on the left lower frame section. If you are going to take it off anyway, it might be easier to just replace the frame member.
from pinwall $14.37 free shipping!
https://www.ebay.com/itm/1997-2003-Honda-GL1500-Valkyrie-LOWER-LEFT-SUB-FRAME-ENGINE-CRADLE/132841017557?epid=1473336061&hash=item1eedf110d5:g:9gsAAOSwmBhb2ytq:rk:52:pf:0
So many roads, so little time
VRCC # 5258
matt
Derry New Hampshire
« Reply #4 on: December 12, 2018, 01:23:42 PM »
Thanks for info, it will probably be Sunday or next Wednesday before I get to bike again. I am just floored as another bolt broke. Seems like everything I touch for first time, two intake bolts doing orings, alternator,  rear exhaust hanger and know this. I sprayed all over and from behind and used a small quarter inch drive ratchet. Oh yea two caliper bolts I thi k even some on forks. I believe Johny overtourque must have worked on this bike.
Avanti
Stoughton, Wisconsin
« Reply #5 on: December 12, 2018, 03:21:29 PM »
I would remove the sub frame and extracted the broken bolt. If you order a used frame section make sure it is not bent before installing it or you will end up worse off than you are.
« Reply #6 on: December 12, 2018, 04:03:53 PM »
I broke the foot peg mount bolt off in mine. I worked for 2 days trying to extract it, to no avail. Buying one from Pinwall was the way to go. I'm sure they can get bent in a wreck, but because of where it's at I suspect most survive even major wrecks just fine.
