nogrey
Nampa, Idaho
« on: December 21, 2018, 06:25:19 AM » |
Hey all, was asked on another discussion thread what the proper way to remove the plastic side covers was. I am glad to see new members and new interest in the Honda Valkyrie, and in the spirit of “the only dumb question is the one you didn’t ask”, I went and made a short video. http://youtu.be/ZtwMOm804Hc
Jonesz
« Reply #1 on: December 21, 2018, 07:07:56 AM » |
Good video Nogrey, I am sure you will save a lot of tabs from being broken with this.
Billyjack
« Reply #2 on: January 08, 2019, 07:25:53 PM » |
Well, I broke a tab off earlier to day. Anyone have and suggestions on repairs?
« Reply #3 on: January 09, 2019, 02:57:03 AM » |
Never truer than with side cover tabs! ... I've seen people yank them off like they were made out of steel. If it has been a few months since I had them off (and it usually is) I look in my owner's manual (still under my seat) and review the removal procedure... they pop right off pretty safely if you do it like in the manual...
People do it several ways...
If you have the broken off tab and wish you could just glue it back on, the side covers are ABS and ABS plumbing glue can work.
Some people replace the broken tab with some velcro.
I've heard of drilling a little hole and using a zip tie, but ...
Billyjack
« Reply #4 on: January 09, 2019, 04:35:48 AM » |
Thanks for the suggestions
Challenger
« Reply #5 on: January 09, 2019, 06:34:46 AM » |
Some good repairs here, I used the paper clip & ABS glue method on a buddy,s Valk, been good for 8 years. Pics are gone though thanks to Photobucket.
« Reply #6 on: January 09, 2019, 06:53:01 AM » |
There are some older threads with how-to instructions on side cover repairs, but the links inside those threads don't work anymore.
« Reply #7 on: January 09, 2019, 07:02:37 AM » |
I used a paper clip and JB Weld. The repair has held for many years now.
dconstruct55
« Reply #8 on: January 09, 2019, 06:02:23 PM » |
Thanks Nogrey, Good video. Nice lookin' ride too.
« Reply #9 on: January 09, 2019, 07:26:55 PM » |
Some good repairs here, I used the paper clip & ABS glue method on a buddy,s Valk, been good for 8 years. Pics are gone though thanks to Photobucket. Could use the right size electrical staple, for household wiring.
da prez
« Reply #10 on: January 10, 2019, 06:32:36 AM » |
Billyjack , I do a lot of repairs to Valks. A new method I use partially comes from this board. The current bike has the side cover and center cover tabs broken. I used blue painters tape on the outside of the cover to locate the tab. I ground off the remainder of the tab and roughed the surface for repair. I cut a piece of donor abs 3/4 x1 1/2 inch. I removed all surface finishes and then used MEK solvent to wet the back side of the cover and donor part. I clamped it in place with 3/4 inch sticking past the cover. Once cured , I used abs black plastic glue as added strength. Now , two choices. The tab hole can be cut and finished or (missing center cover tab) an oval grommet(side cover lower) can be installed in the center cover with a little trimming. The MEK makes a world of difference when using black abs glue. Holes can be filled by taping over after prep .Fill from the inside. I even use abs to fill seams that get painted. Do not rush the curing.
da prez
ShiftHappens
« Reply #11 on: January 10, 2019, 12:56:09 PM » |
I have found that applying a small amount of lubricant (I use Sil-Glyde) to the grommets is very helpful.
« Last Edit: January 10, 2019, 12:58:15 PM by ShiftHappens »
1999 Interstate
« Reply #12 on: January 14, 2019, 12:29:10 PM » |
Sounds like it would be very helpful in helping the side covers blow off on the freeway. Those things need to be a bit tight. If you need a lube use a dab of spit, it will dry and not leave it slippery
