November 14, 2025, 07:16:12 AM *
Author Topic: Wiring query  (Read 1161 times)
john m
The Fly
UK
« on: December 26, 2018, 09:28:16 AM »
Hi all. Happy Christmas.  I have removed my trunk from my 2000 Interstate with the intention of Super valking the bike. I thought I had done my home work and I have a new rear tail light and the wiring loom from fender plug to tail light / indicators. I also have the section from the fender plug to the wiring connection in the right hand panel. I have fitted it all and now find the harness connection behind  the right hand panel only has four wires? not five as required.  No green/ yellow connector? for the front brake light?  I have worked it out that this connection is part of the flat three wire trunk connection behind the right hand panel. what I need to know is which colour wire do I connect the green/ yellow  brake power wire to?  thanks
« Last Edit: December 26, 2018, 10:52:01 AM by john m » Logged
« Reply #1 on: December 26, 2018, 11:24:34 AM »
Any green would be my first guess.
9Ball
« Reply #2 on: December 26, 2018, 12:01:01 PM »
Green is ground on our bikes....
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
knockdolian
« Reply #3 on: December 26, 2018, 12:24:38 PM »
Green is earth. DO NOT CONNECT ANYTHING TO IT. looking at my manual there should be.
Green = earth
Blue= right signal
Orange = left signal
Brown = light
Green/ yellow = brake.
What colour wires are on your tail light loom and what colour on your connector on the bike ?
There is no front brake light wire. Both front and rear are common at the junction. Does anything wort when plugged in ?
« Last Edit: December 26, 2018, 12:29:37 PM by knockdolian » Logged
john m
The Fly
UK
« Reply #4 on: December 26, 2018, 12:46:41 PM »
Thanks, yes its the green/ yellow front brake power wire. I have green, earth. brown and white and green and red. all in the three connector I/S connection, I now have the standard wiring loom to the back fitted.  the green / yellow either connects to the brown/white or green/red.
« Last Edit: December 26, 2018, 12:50:58 PM by john m » Logged
knockdolian
« Reply #5 on: December 26, 2018, 12:59:32 PM »
Well the only thing I would do is connect a volt meter or test light to brown / white  and see if here is power when you hit the brake. If yes that’s it. If no, it’s the other one. Is the back light you have a Valkyrie one ? I couldn’t find those wire coloured in the book.
john m
The Fly
UK
« Reply #6 on: December 26, 2018, 01:15:34 PM »
Thanks again, yes the rear light I have put on is a new valk standard one, I have changed the two harnesses to the standard type and unplugged all the I/S ones. everything works apart from brake light, which is this green / yellow wire. I notice on the I/S wiring diagram that the rear trunk brake light has both the brown /white and green/ red wire attached to it plus the earth green. one must be for the front brake and one the rear brake pedal.
knockdolian
« Reply #7 on: December 27, 2018, 12:26:45 AM »
No, the front and rear brake are on the same wires. Make sure you have power at the green yellow wire when you apply the brakes. You will only have 3 wires to the tail light. Earth, light and brake light.
john m
The Fly
UK
« Reply #8 on: December 27, 2018, 07:29:19 AM »
Thanks for that, so the yellow/green wire for the brakes goes to which one, the green/ red or brown and white?  I will try both.
john m
The Fly
UK
« Reply #9 on: December 27, 2018, 09:59:10 AM »
My Interstate is a 2000 Canadian model,and for some reason the green/yellow brake light wire connects to the green and red wire in the three pin connector. I have soldered a piece of wire with the correct female connector on to the G/R wire which allows me to just plug in the G/Y,  so I can still plug in the trunk connector. it all works. Maybe Canadian models have slightly different wiring colours, it all looks original.
« Last Edit: December 27, 2018, 10:22:03 AM by john m » Logged
knockdolian
« Reply #10 on: December 27, 2018, 12:06:35 PM »
Glad your sorted
