November 14, 2025, 05:22:47 AM
Nut Cage Mod-Question
Topic: Nut Cage Mod-Question (Read 1199 times)
Fazer
January 09, 2019, 05:18:37 AM »
I have done the mod on my bike, but getting ready to help my son install a car tire on his Valk. Can anyone tell me the thread size/pitch for the square nuts. I plan to use the stock bolts with a lock nut in place of the caged square nut. If his tire is too wide, I will go with a carriage type bolt from the inside, but hope we can get away with using what is there.
Nothing in moderation...
da prez
Wilmot Wi
Re: Nut Cage Mod-Question
January 09, 2019, 06:41:30 AM »
A carriage bolt is usually a grade three bolt. I use a grade eight bolt installed from the inside with a hardened washer. Over kill , yes. Future problems ,no. I start with a full thread bolt that is to long and tighten a nut and washer on it. I then measure the thread left. Now , buy a bolt with an unthreaded shank the length you need and cut off the extra. I do it after installing. This method has the bags or rails on an unthreaded shank. Make sure the bolt tightens.
da prez
January 09, 2019, 07:24:30 AM »
The front bolt size is 10mm X 1.25 pitch. The smaller bolt is 8mm X 1.25 pitch.
SCain
Rio Rancho, NM
January 09, 2019, 07:29:35 AM »
I just used the square nut, its larger than a standard hex nut and you already have them. The nut cage is really the only part that would rub a tire. I used the square nut because they don't spin when tightening the fender support bolt. I remove the lower section of the fender for tire changes. My .02
Steve
Cliff
Manchester, NH
January 15, 2019, 06:24:57 AM »
I was able to do the "washer mod" to prevent the car tire form rubbing with good results.
http://www.valkyrieforum.com/bbs/index.php/topic,69323.msg676236/topicseen.html#msg676236
VRCC # 29680
MnM Valk 97
Russellville, AR
January 24, 2019, 06:52:06 PM »
When I saw "Nut Cage" I thought this was going to be a post about cars...
1997 GL1500CT
2015 GL1800C
=> InZane XXV
