November 14, 2025, 05:21:14 AM *
Author Topic: No start after bike falls over  (Read 1951 times)
Mofla
San Antonio TX
« on: January 24, 2019, 07:11:21 AM »
Parked on dirt , bikes fell over. No damage, but won’t start now. Turned key on & off, cycled kill sweet &
 checked battery terminals ? Gonna check angle sensor & relay, hope the manual is walks me thru that . Appreciate the input ! Mofla
« Reply #1 on: January 24, 2019, 07:42:48 AM »
check angle sensor
That'd be the first thing to check on my list...
Earl43P
Farmington, PA
« Reply #2 on: January 24, 2019, 10:59:21 AM »
Pull one plug wire and check for spark with a couple short cranks.
If spark is present, you can forget about the tip over circuit, it has reset as designed.
Mine got upended while it was running (years ago) and quite a bit of gas flowed into the dirt. It took a few cranks to start afterward, probably yours just needs the float bowls refilled, depending how long it was on its side. Mine was toppled on its right side for quite a while (>1 hour) until I was able to get help up-righting it.
I recommend SHORT cranking periods followed by long pauses. That'll engage the vacuum, enabling fuel flow from the petcock. LONG cranks kill the battery (spark is the first thing to go away as the battery depletes).
Report back!!
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
JimC
SE Wisconsin
« Reply #3 on: January 24, 2019, 03:01:37 PM »
Did the bike go over to the left?
If it did, check for a bent kick stand and the and associated electrical connections.
Jim
Jim Callaghan    SE Wisconsin
Mofla
San Antonio TX
« Reply #4 on: January 24, 2019, 03:11:17 PM »
Thank for the inputs,,, to be more descriptive, Its not tuning over all. Like a sensor is not allowing the starting circuit to complete? Yes it fell to the left , I will concentrate on that area for a while . Trying to figure out how to by-pass bank angle and or relay , all I’m getting is a headache!!! Thanks for the help !!!
« Reply #5 on: January 24, 2019, 03:49:35 PM »
Jim
I think you are on to something here. Maybe some mud or dirt in the side stand switch. Mofla, have you tried starting in neutral ? Have you been able to look at the bank angle sensor yet ?
Mofla
San Antonio TX
« Reply #6 on: January 24, 2019, 05:33:05 PM »
Located and removed sensors & relays . I really don’t know how to check or by-pass despite some knowledge with an omnmeter . If the kickstand indicator is working, wouldn’t that rule out malfunction
Of that switch ?? Waiting for some magic advice & I do thank you for the participation!!!
matt
Derry New Hampshire
« Reply #7 on: January 24, 2019, 05:59:56 PM »
Start with basics did you happen to hit kill switch?
Mofla
San Antonio TX
« Reply #8 on: January 24, 2019, 06:20:42 PM »
Yep I did ,,, haven’t taken it apart yet , but that’s coming . I’m hoping it is something simple ,,,
F6BANGER
Albuquerque NM
« Reply #9 on: January 25, 2019, 05:45:27 AM »
Sometimes through the panic of our bikes being down we overlook the obvious.  Key on, ignition on, clutch lever pulled in, bike in neutral, kickstand up. The basics, Im sure you tried this. If so then try the things the others have said.
Mofla
San Antonio TX
« Reply #10 on: January 25, 2019, 06:54:23 AM »
I agree and I keep thinking I’m missing something simple. I have check them all and will do it again ! Thanks , don’t like being without my Kandy!!
« Reply #11 on: January 25, 2019, 07:20:10 AM »
Also try cycling the kill sw off/on some.  If it needs cleaning/maint it could be the culprit.  My "George" needs attention there and he isn't high miles.
Mofla
San Antonio TX
« Reply #12 on: January 25, 2019, 11:16:51 AM »
Thanks buddy ! Next on the list !
Mofla
San Antonio TX
« Reply #13 on: January 26, 2019, 01:26:43 PM »
Lesson learned, don’t assume your in neutral cause the green light is on !!  uglystupid2
« Reply #14 on: January 26, 2019, 01:32:29 PM »
You got it started ?
Mofla
San Antonio TX
« Reply #15 on: January 26, 2019, 02:40:45 PM »
Yeppers !!! Kept messing with the kill switch & something told me to cycle the shifter , took it out of green light neutral, put it back in green light neutral and boom !!! Good feeling!!
« Reply #16 on: January 26, 2019, 02:43:10 PM »
Bone
« Reply #17 on: January 27, 2019, 06:39:18 AM »
Glad you found it. I had a similar thing happen and didn't think it was your solution.
I tried everything to start mine no luck. Went to push it a few feet to better safety and it was in gear
with the green neutral indicator on !
Pushed the lever into first gear position and back to neutral it rolled. Hit the start button it fired.
Had to hurry and call my brother-in-law he was starting a 20 mile drive with a trailer to get me home.
9Ball
« Reply #18 on: January 27, 2019, 06:48:32 AM »
You should also check your dragon drool tube...they tend to need draining after a tipover.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Mofla
San Antonio TX
« Reply #19 on: January 27, 2019, 10:48:23 AM »
Good thought! On another note, I could have avoided all this aggravation had my clutch switch been functioning. Have one ordered !
RonW
Newport Beach
« Reply #20 on: January 27, 2019, 10:59:12 AM »
..... Went to push it a few feet to better safety and it [the transmission] was in gear
Did you ever find the culprit that lit up the neutral light when the transmission wasn't in really in neutral? Or was it just an isolated incident?
2000 Valkyrie Tourer
« Reply #21 on: January 27, 2019, 11:21:46 AM »
I've had my light on many times, and the bike wasn't in neutral. 5-10 times or so. But I always start with the clutch pulled in. But then, I've also had it in 1-2nd gear too, and when I release the clutch it pops into neutral. Hard to get a non-running engine into a gear when cold.
« Reply #22 on: January 27, 2019, 01:30:10 PM »
You’ve been starting it in neutral previously ? It’s also a safety thing in case you stall out an intersection or something.  cooldude
Bone
« Reply #23 on: January 28, 2019, 02:02:34 AM »
No I didn't I did research some. I'm now 71 the tourer has 156k miles I decided to see what happens. If I get a "no start" when the button is pushed I will rock the bike back and forth to see if it is a neutral problem. It hasn't happened again. I always park in neutral in the garage in gear on the road if not a level location.
I always start in neutral.
« Last Edit: January 28, 2019, 02:04:22 AM by Bone » Logged
Mofla
San Antonio TX
« Reply #24 on: January 28, 2019, 02:55:54 PM »
Procrastination on replacing the clutch switch is my bad ! As yes when you die at a light you really appreciate that convenience! Yes I have had the green light on before and not been in neutral! I guess
Because of the falling over my brain wasn’t as sharp as it could have been ! I know it wasn’t the beer !
Thanks once again dragon slayers !
RonW
Newport Beach
« Reply #25 on: January 29, 2019, 03:56:45 AM »
I haven't replaced a bad clutch switch on my Shadow 600, and it is inconvenient at a stoplight, indeed.
« Reply #26 on: January 29, 2019, 12:59:32 PM »
I've repaired a few clutch/brake switches. Unplug and remove. Look carefully and you'll find small hole in the switch. Spray contact cleaner in that hole as you click the switch repeatedly. Check with ohm meter and reinstall. Never replaced one yet.
